Dear all,
I hope that you R-guys can may be point me in the right direction about where to start searching for my problem. Here is the story:
I own a 2004 Volvo S60R and I recently started to have problems with the car. I took it to the dealer and they got the following codes out of the car:
CEM-1D04
ECM-130A
ECM-262A
ECM-6814
ECM-531D
ECM-2100
The issue with the car: When I start the car in the morning it starts fine, I can drive it for a few miles and it seems to run fine until I get to work. Once I leave it there for a few hours (2-3) and try to start it again after that the problems start. The car has difficulties starting and keeping the RPM, they fluctuate and the car stalls. I am able to sometimes start it and luckily keep the RPM's to get back to my house.
Anyhow this started about a month ago, before that I started noticing that the cars was studdering lightly under normal driving conditions and progrssively the problem got worse and worse until now where the engine basically would stall at a stop light, as well as when I am driving normally. The car would start studdering and shaking while moving and it will finally stall. Could you please let me know what could be the problem?
I did clean the MAF sensor with brake cleaner, cleaned the throttle body, as well, and replaced the fuel filter. Anyhow, I hope that someone would be able to give me an advice as soon as posible please.
Thank you for your time,
Respectfully,
George
CEM-1D04
ECM-130A
ECM-262A
ECM-6814
ECM-531D
ECM-2100
Respectfully,
George
