Discussion Starter #1
Hi all,
A couple weeks ago my car wasn't starting so well, seemed like it did a "mini sputter" before it turned over, so I got a tank of high test (I usually get mid-grade) and tossed in a bottle of STP fuel injector cleaner to boot. Shortly there after the Check Engine light went on, didn't put 2 + 2 together at first, but the code read out "slight air leak" or something like that, so I am thinking gas cap now, have any of you had issues with FI cleaner messing up your gas cap valve?
Thanx,
It can be there is a loose hose somewhere too.
Gas cap throws the code for LARGE leak
If you have the SMALL leak code, it's something else
GOOD information for the rest of us too. I knew I liked JRL for a reason. :D
