2004 S60R M66 – Black Sapphire exterior with Nordkapp interior
1 reading
4.3K views 6 replies 5 participants last post by  DTra1n
#1 · (Edited)
Up for sale is my beautiful 2004 Volvo S60R with Black Sapphire metallic paint, Nordkapp interior and 6 speed manual transmission and 113,xxx miles.
I am a Volvo enthusiast. I currently own 4 qty P2R’s and a total of 11 Volvos altogether. The time has come to “thin the herd” as I simply do not have the space or time required to keep them all, so this extremely nice S60R will have to find a new home. I’ve owned it since 2015. This car has sat in my garage for the last 4 years as it is the nicest of my P2R’s so I have not driven it.
This car is completely original. No modifications of any kind have been made. Everything on the car works as it should and there are no codes of any kind. If you are looking for a pristine example of a P2R, this is it. As can be seen in the photos, both the interior and exterior of this car are in excellent condition.
I have a clean title (no lien, no flood, no salvage) in my name.
The VIN is YV1RH52Y642412816. I have an AutoCheck which I will send upon request. I’ve included the AutoCheck snapshot with the photos of the car.
Items replaced/repaired/serviced while I’ve owned it:
  • Clutch and flywheel replaced
  • Clutch slave cylinder replaced
  • Clutch master cylinder replaced
  • Rims refinished
  • Both rear wheel bearings replaced
  • OEM Air and oil filters and oil (Mobil 1 synthetic) changed within the last within last 5 miles
Items replaced/repaired/serviced by prior owner:
  • Timing belt and water pump
  • Front brake rotors
  • Brake pedal sensor
  • Fuel pressure sensor
  • Front control arm bushings
  • Front and rear stabilizer links
  • #3, #4 & #5 ignition coils
  • Upper torque mount
  • Front struts
I have a stack of service/part receipts/invoices for the items mentioned above. Prior to purchasing the car, I spoke with the previous owner. He confirmed that the car had oil changes exclusively using synthetic oil (this can be confirmed by the receipts included).
This car spent most of it’s life in Missouri, limited use in Minnesota on the roads in the winter so the underside is very clean – no rust except for the outer shell of the muffler.
As can be seen from the pictures, it is in near perfect condition. As a Volvo enthusiast I hate to let it go, but I simply do not have the space to keep it. The price is $14,000. Please do not waste my time or yours with lowball offers.
I've posted as many pics as I can below, but there are many more here including a close op of the metallic paint:
2004 S60R Black Sapphire/Nordkapp M66
Interested, could you send me a message? I haven’t posted enough to enable messaging.
