I belive the amp on my 04 R is overheating i dont run it very long at a volume that can be heard with windows down while driving. Next thing i know it cuts off only the center speaker is on then after a min it all comes back it did this 5 times today on the way home which is a 20 min drive. i was woundering anything you can do like add a fan or something post up what you have done or ideas thanks <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
Yeah, I've only had it shut off after I've been playing it fairly loud and after about 1.5+ hours. <p>But yeah, that's definitely a sign of a problem. Putting computer fans on it WOULD work and keep it cool, but that's kind of ghetto. Maybe you could pop that amp open and see if any parts are visibly bad if it isn't under warranty.
Mine has cut out on very hot days when I have the music blasting for an extended period of time. It is a known issue, but it sounds like yours is more problematic.<p>IIRC there have been fan mods done by people.
Would it be better or even possible to replace the factory amp with an aftermarket on eif so what should i look for?
Re: (97GLTbrick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>97GLTbrick</b> »</i></TD></TR><TR><TD CLASS="quote">Would it be better or even possible to replace the factory amp with an aftermarket on eif so what should i look for?</TD></TR></TABLE><p>Yeah, it would be possible. Pretty easy, even. I'm sure you could tap into the existing output wires coming from the headunit, or even just buy this beauty: <A HREF="http://cgi.ebay.com/ebaymotors/Volvo-Stereo-Radio-Aftermarket-HU-to-Factory-Amp-Cable_W0QQcmdZViewItemQQimsfpZTL0905141410013r10133QQimsxZ20090514QQitemZ200341873169QQsalenotsupported" TARGET="_blank">http://cgi.ebay.com/ebaymotors...orted</A><p>all the speaker wires should be located where the amp is, so you just hook them up to the new amp. <p>
Re: (Jexx)
The oe amp is a servicable, but not very exciting amp. It has one great thing going for it: it fit's nicely under the front seat. Anything else you replace it with is likely going to have to be mounted in the rear.<p>Check to see which amp you have, it comes in two flavors: pa-200 & pa-300, 200 and 300 watts, respectively. If you have the former, maybe getting the latter will solve your problem.
Thanks for the replies all i will look into those things
