1 - 1 of 1 Posts
Car went in for a/c charge. Garage manual set a/c compressor clutch now car has crank but no start. Can smell gas after long cracking. Levels and filters are good. Checked engine codes boost pressure related. First question, other than the engine ecm what module can cause crank no start? Noticed that when plugged in with scanner the engine coolant temp and inlet air temp are way out, -41 degrees C ambient temp is correct 18dg C
1 - 1 of 1 Posts
