1 - 1 of 1 Posts
2003 Volvo S60 2.5t AWD - $1400
Timing is going. Needs Timing Belt/Water Pump replaced. Ian @ Maitland Importers (Orlando, FL) quoted me $1000 for the job. Parts on IPD are under $400 for the kit.Would like for this to go to someone who can make real use of the parts installed.
Automatic. 185,800. Ashe Gold/Beige.
Pictures:
https://offerup.com/item/detail/603480993/
VIN - YV1RH59H932238213
-235/45/17 Michelin Pilot Super Sport tires on all four wheels.
-15mm H&R Front Spacers, 20mm H&R Rear Spacers.
^ This eliminates the wide turns and tire rubbing that these Volvos are known for.
-305mm StopTech Slotted Rotors on all fours.
-Brembo Ceramic Pads on all fours.
---Suspension---
-Bilstein Touring Front Struts.
-Heavy Duty Bilstein Front Strut Mount Kit.
-IPD Heavy Duty Spring Seat Kit.
-IPD 25mm Anti-Sway Bars, Front and Rear.
-IPD Heavy Duty Sway Bar Endlinks, Front and Rear.
-IPD Heavy Duty Control Arms.
-IPD Heavy Duty Ball Joints.
-IPD Heavy Duty Inner and Outer Tie Rods.
---Engine Reliability Enhancements---
-IPD Heavy Duty Stabilizer Bar Mounts.
-IPD Polyurethane Top Engine Mount.
-IPD Polyurethane Bottom Transmission Mount.
-New Rubber Passenger Engine Mount.
-New Rubber Hydraulic Engine Mounts, Front and Rear.
1 - 1 of 1 Posts
