Hi all, the headlights on my V70R have stopped raising to their set position, I understand there is a level sensor linked to the rear suspension which controls the headlight level, and I suspect it has failed causing the problem. Can anyone confirm this could be the problem, and do they know where the sensor is?
Discussion Starter · #2 ·
Hi again, just read something about 'ride height sensors for headlight leveling' in another thread, so can anybody shed some light [no pun intended] on where these are located?
Thanks. :thumbup:
Try searching the R forum, and if you can't find anything post this in there. I'm pretty sure I've read about others having this problem.
Probably need to recalibrate the SUM module.
Need someone with VIDA and a DiCE module to do it though. Also its important to follow the procedure carefully.
Sent from my SGH-I777 using Tapatalk 2
