1 - 2 of 2 Posts
Hi all, I am hoping for some advise on something that has me stumped so far - I can't find any related threads on this.
I have a 2002 V70, both rear window controls are able to operate their rear window. Both front window controls are not illuminated and do not operate their respective windows.
The front passenger door lock control does work, and when it is pressed, the switch briefly illuminates. During this time (half a second or so) the window control also works.
The drivers control assembly is not working at all.
The remote entry fob operates as it should, all door locks seem to work.
Hoping someone has a few ideas on where to start checking in order to get the front windows working again.
Thanks
Sounds like a DDM internal fault. That's the Driver Door Module and its incorporated with the Master Window Switch. A new one will need to be programmed. Using VIDA will give you a better idea. A used one may work ok if same part number and options on vehicle from donor.
1 - 2 of 2 Posts
