1 - 20 of 20 Posts
2002 Volvo V70 T5
$8,000 obo
132,xxx miles
5 Speed Manual
Nautic Blue Metallic Exterior/ Sport Graphite Leather Interior
Good Condition, non-smoker
This is the rare V70 with the T5 engine and 5 speed manual transmission. Available with the stock 247hp or an optional MTE Chip tune giving it around 280hp. Features include Dual Heated and Power Front Seats, 4 Disc CD Changer (HU-803) with Premium Sound, Dynamic Traction and Stability Control (DTSC), Dual Rear Booster Seats, Power Windows/Door Locks/Mirrors, Moon roof, Dual Zone A/C, Dual Integrated Booster Seats
and V70R rear spoiler. The car looks completely stock and is mostly stock mechanically as well.
Clean and clear title in hand. Clean Carfax is available upon request. Please email me if you are interested in a test drive or if you would like additional pictures.
Here is all the work I have done:
MTE Performance Software (revert to stock tune avail.)
Synthetic Oil and Filter Change w/ Pennzoil Ultra 5W-30
New OEM Clutch, Pressure Plate, Throw-Out Bearing and Slave Cylinder
Used OEM Dual Mass Flywheel with 15K miles
New OEM Engine Air Filter
New OEM Fuel Filter
New OEM Volvo Spark Plugs
Volvo S60R/V70R Exhaust Manifold w/ new gaskets/studs/nuts
Turbo Rebuild Kit
IPD TCV (Turbo Control Valve) rev1 w/ silicone vacuum lines
IPD Silicone Boost Tubing Kit
IPD HD Turbo Compression Bypass Valve
Transmission Fluid Change w/ Redline MT-90
New IPD HD Subframe Bushings
New Engine Stabilizer End Mounts
New Front/Rear/Side Motor Mounts
New Monroe Front Struts and Rear Shocks
New Rear Brake Rotors and Pads w/ new parking brake shoes & hardware
Front Rotors and Pads replaced 10K miles ago
New Front and Rear Brake Caliper Seals
New OEM Brake Booster
Brake Fluid Change w/ DOT 4
New OEM Power Steering Reservoir
Power Steering Fluid Change
Volvo 3 Spoke Steering Wheel (Original 4 Spoke with airbag incl.)
New Rear Hatch Struts
New Cabin Air Filter
Air Conditioner Condenser Clutch serviced and A/C Recharged
New Windshield
Yokohama AS530 Tires with 8/32nds Tread and 17 Inch Tethys Alloy Wheels
Work Previous Owner Had Done:
Timing Belt, Tensioner, Idler Pulley, and Water Pump
New Radiator and Thermostat
New Serpentine Belt
Short Shifter Kit (Original shift kit incl. with Momo Shift Knob)
IPD Poly Engine Stabilizer Mount
New Poly Control Arm bushings
I'm selling for a friend, but I can answer all of your questions. Please email me at [email protected], also leave a phone number so I can verify that you are not a scammer. Thanks.
Was this car originally from the MD/DC/VA area?
Griff33's old car.
If so, it was very well kept in its early years
Good looking v70 from that tweener era. if you still have it in 3-4 months or so and im back out in the denver area I'd totally come look at it.
price is heading to affordable. maybe put it on ebay and see how that works out.
Craigslist if you haven't already...
Sold my 1998 T5m with 219k miles for $4750, you should be able to get 1250 more quite easily as yours is 4 years newer and 90k less miles!
Edit: now I see you have it on CL, holidays are a hard time to sell it but you should get a lot of interest once they are over. Ebays a good idea too.
how long did it take to get that 4750? if your car was in tip top shape that's a decent price, not that high really. some folks do not want to wander into 99+ territory with too much electronics for their tastes.
Hey! I'm just dropping by to say that your car is GORGEOUS. Out of my price range though, by a lot. Best of luck to you and I hope your car finds a wonderful new home.
Only took me a month. It was tip top mechanically just like the OPs car seems to be, but the paint was worn.
Point is I think this car is a fair deal based on the description!
Discussion Starter · #18 ·
Sorry for the late responses, I've been on holiday,
bimmerd00d: Sorry, I'm not interested in any trades.
1fast7: Yes it is, but someone is in the process of buying it. I responded to all emails about the car just a few minutes ago. If you just didn't get a response, you're more than welcome to ask questions about the car until its sold.
1 - 20 of 20 Posts
