1 - 1 of 1 Posts
Went to the Volvo Dealer for another issue and was told that the DIM unit in my Cluster is bad and will need to be replaced... Seems that the only fix for this is a new cluster... I was under the assumption that you can swap out the cluster with another salvage yard unit and reprogram to match the mileage as recorded on ECM... But as explained by mechanic at dealer this is not the case as it must be recorded/burned the first time?? Anyone else experience this? The $1400 part and labor seems pretty steep....
1 - 1 of 1 Posts
