1 - 8 of 8 Posts
I opened up the trunk speaker covers to find nothing behind them. If I just get other XC70 rear tweeter speakers and install them will that work? do those look like the right connectors for the tweeters? I am not even sure I have a center channel speaker, how can I pull the center grille off?
You probably have the standard HU 613, no center speaker, no Dolby
I thought the tweeters came standard on all XCs, perhaps a speaker went bad and they were both removed.
To your answer, yes, plug and play
thanks good to know! I am picking up some used speakers tomo and see if it works out.
if I wanted to add the center channel, what else would I need to make it happen?
You'd need the HU-803 head unit and the factory amp+harness.
and the center speaker
Not worth the money unless you upgrade the speakers
yup that's what I was thinking.
I have not looked into it but I heard upgrading the stock stereo to an aftermarket deck is a pain in the a**? I had done it in my S70 and it was really easy why would it be any different in the XC?
update: installed the tweeters, it was plug and play and they worked.
No difference really, perhaps even easier as you don't need to file down the opening if you went with a double din
1 - 8 of 8 Posts
