I picked up a T5 auto that has the typical delayed shift problem. Picked it up for cheap to replace a Jetta. Much more room in the V70 that's for sure.
I than picked up some parts.
A M56 manual trans from a 2003 S60 non-turbo car. The tag is rubbed clean so I don't know if I ended up with a M56L or a M56H but I assume it's an H.
I got a manual shifter with cables from a 2004 S60.
I bought a pedal set from a 2004 V70 R
A stock dual mass flywheel from a 2001 V70
The last used part I got is a set of XC70 roof rails.
The new parts I got are:
Aftermarket parts:
A clutch set which included the slave cylinder. I got a 2001 clutch set and the
A clutch master cylinder for a 2001 V70 - more on this later, there was a problem
I ended up having to get a set of axles. The auto axles are the correct length and have the correct splines. The ONLY difference is the seal surface diameter. The auto axles are too small and don't fit the manual axle seals.
Volvo parts
A clutch line for a 2001 V70. I couldn't find this used so I ordered one. (Pt. # 30759377)
Rear transmission mount (Pt. # 9485192)
Flywheel bolts (Pt # 9454743)
Clutch pressure plate bolts (Pt # 959219)
I used speedtuningusa for the ECU flash.
Leni
Aftermarket parts:
Volvo parts
Leni
