Sounds like a perfect opportunity to rebuild and/or beef up some internals either for longer life or MORE POWAH.
Have you checked with Volvo & Saab dismantlers in Rancho Cordova? They're close enough to pick the motor up yourself if they have one.
http://www.vandsautodismantlers.com/
Just from checking the owner's manual, the engine does have the same bore, stroke, and compression ratio as a B5234T3, (the T5 motor) which there are plenty of.
Others here will know better if that's an exact substitute, I'm not sure what the other differences are. But I suspect it comes down to the turbo and the boost (ECU). If so, then you can just use one of those for the long block. It might also have different variable cam timing.
