I'm due for a transmission flush. The last time we got it checked, it was back in March and the fluid was light brown. It's now August and it's pretty much due for a flush. I won't be doing it myself but I will purchase the fluid. What fluid do I purchase and how much do I need? I've read that the Toyota T1V transmission fluid will do?<p>How much air should I have in my S70? The tires were filled with nitrogen at 32PSI/29PSI front/rear a few months ago. The manual states like 32PSI/29PSI I believe, but I've heard that you should just keep it at 33PSI front and rear now. Is this correct?<p>Also the brakes seem to be squealing a bit under braking. I think it's the brakes because before, there seems to be light squealing every once in a while under light braking. However, I also seem to be experiencing a random high pitch sound when driving normally. Sorry if I'm being confusing on this.<p>Finally, what tires are we supposed to use? The sticky <A HREF="http://forums.swedespeed.com/zerothread?id=6843" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=6843</A> says that the correct tire sizes are 195/65/15, however we have Michelin Harmony 195/60/15 on the car.
Re: 2000 S70 SE Maintenance (geokilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>geokilla</b> »</i></TD></TR><TR><TD CLASS="quote"><br>Finally, what tires are we supposed to use? The sticky <A HREF="http://forums.swedespeed.com/zerothread?id=6843" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=6843</A> says that the correct tire sizes are 195/65/15, however we have Michelin Harmony 195/60/15 on the car.</TD></TR></TABLE><p>195/60/15 is the OEM size for the tires.
Re: 2000 S70 SE Maintenance (V70 Brad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>V70 Brad</b> »</i></TD></TR><TR><TD CLASS="quote"><p>195/60/15 is the OEM size for the tires.</TD></TR></TABLE><br>Thanks for the clear up. Maybe someone should fix the sticky then.<p>So can anyone chip in on the maintenance stuff?<p>Thanks.
All of the information is in the owners' manual. Tire pressures are also on the inside of the fuel door.<br>
Re: 2000 S70 SE Maintenance (Wayne T5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Wayne T5</b> »</i></TD></TR><TR><TD CLASS="quote">All of the information is in the owners' manual. Tire pressures are also on the inside of the fuel door.<br></TD></TR></TABLE><br>I realize that but people say it also depends on your tires? Plus I've heard that keeping them at the same pressure is better, despite Volvo saying that it should be 32/29 PSi.<p>As for the transmission fluid, the post over <A HREF="http://volvospeed.com/vs_forum/index.php/topic/111753-2000-s70-se-dying-tranny/page__view__findpost__p__1503554" TARGET="_blank"> here</A> says that I can use the Toyota T1V fluid, but I'm not entirely sure on that since the manual states to use Volvo fluid, and we all know how expensive dealer stuff is.<p>What about the brakes squealing? We're using stock pads and rotors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>geokilla</b> »</i></TD></TR><TR><TD CLASS="quote"><p>As for the transmission fluid, the post over <A HREF="http://volvospeed.com/vs_forum/index.php/topic/111753-2000-s70-se-dying-tranny/page__view__findpost__p__1503554" TARGET="_blank"> here</A> says that I can use the Toyota T1V fluid, but I'm not entirely sure on that since the manual states to use Volvo fluid, and we all know how expensive dealer stuff is.<br></TD></TR></TABLE><p>If you have the 5 Speed Automatic, you need JWS 3309 Spec fluid. As somebody pointed out, Toyota TIV fluid is ths spec. You can also get JWS 3309 Spec fluid online; it is made by Mobil. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>geokilla</b> »</i></TD></TR><TR><TD CLASS="quote"><br>I realize that but people say it also depends on your tires? Plus I've heard that keeping them at the same pressure is better, despite Volvo saying that it should be 32/29 PSi.<p>What about the brakes squealing? We're using stock pads and rotors.</TD></TR></TABLE><p>The fuel door on my '99 says 36/36 with an optional pressure of 34/31.<p>Squealing brakes are often caused by pad backs or slide pins that need to be lubricated.
