I have a 2000 c70 that is leaking oil from the bottom front, it is only leaking when you are driving, if the car is just idling no leak. Please help me.
How many miles? When did you last change the oil? Has the PCV system been replaced recently? Where in the front is it leaking? Can you post a picture?
my car has 157,000 miles pcv has not been replaced , we just had the front crankshaft seals replaced along with the timing belt. it is leaking in the front passenger side, i don't have a picture. oil was changed 2 months ago
Probably clogged pcv or cracked hose on the pcv to block drain. Recommend changing pcv components and cleaning. I had the same thing happen on my R.
