Couple of questions about the 2019 XC60. I have a 18 XC90 and these things are slightly different on mine.
First question, is there a way to disable the right rear view mirror from automatically folding down when you put it in reverse? I had an X3 that used to do this and if I selected the left mirror to adjust with the button on the drivers door it would not fold. I cannot figure it out on this car though.
Second question, when I put my XC90 in park and open the door, it automatically turns the car off. Is there a way to activate this feature on the XC60?
Thanks guys!
For Number 1
Automatically tilting when parking
With this setting, the door mirrors will automatically tilt down when reverse gear is engaged. The
folded position is preset and cannot be adjusted.
To immediately return the door mirrors to their
original position, press the L or R button twice.
1. Tap Settings in the center display's Top
view.
2. Tap My Car Mirrors and Convenience.
3. Under Exterior Mirror Tilt at Reverse,
select Off, Driver, Passenger or Both to
activate/deactivate and to select which mirror to tilt.
Second one sounds like having the automatic start/stop turned on.
Thanks guys!
My XC60 does this. I do have start/stop turned on, but there are a few exceptions that can keep it from happening (like not having it in park ;) )
