1 - 16 of 16 Posts
Took today off work and want to get these 2 things done:<p>1. where is the cabin\pollen filter located? I've checked under the glove compartment but have no clue where it it.<p>2. do I need to remove the intercooler hose to replace the spark plugs?<p>thanks,
Re: 2 simple questins (blackTT55)
Answer to question #2<p>You do not have to remove it completly, just loosen it enough to remove the cover and get to the plugs. Also will be a good idea to have a vacuumcleaner handy. There will be a lot of small broken plastic pieces. You'll know what I mean when you remove the cover.<p>
For the Pollen Filter, go o this thread;<p><A HREF="http://forums.swedespeed.com/zerothread?id=59284" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=59284</A><p>
Re: 2 simple questins (wrodri54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>wrodri54</b> »</i></TD></TR><TR><TD CLASS="quote">Answer to question #2<p>You do not have to remove it completly, just loosen it enough to remove the cover and get to the plugs. Also will be a good idea to have a vacuumcleaner handy. There will be a lot of small broken plastic pieces. You'll know what I mean when you remove the cover.<p></TD></TR></TABLE><p>Got it... any idea where the pollen filter is located?
Remove glovebox and it will be staring you in the face
Re: 2 simple questins (JRL)
I guess you could remove the glovebox.<p>I had no problem replacing the filter leaving the glovebox alone.<p>
Re: 2 simple questins (grovesj2)
The small broken plastic pieces come from the FLEXIBLE WIRE LOOM that cover the coil wires.<p>Looks like the engine heat dries them up and they break apart from vibration. Wasn't a real problem, but I vacuumed them out before I took the plugs out, didn't want any of the pieces falling into the cylinders thru the spark plug holes.<p>
Got em both done yesterday but it was a b*tch... <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/mad.gif" BORDER="0"> <p>why..tf did they put the intercooler hose in that position <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0"> <p>the cabin filter was also a b*tch to replace.. but at least now the ac vents blows a lot stronger
you really thought the cabin filter was a PITA?<p>I had an '01 s60 t5 and it was extremely easy to replace.
Re: 2 simple questins (phuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>phuz</b> »</i></TD></TR><TR><TD CLASS="quote">you really thought the cabin filter was a PITA?<p>I had an '01 s60 t5 and it was extremely easy to replace.</TD></TR></TABLE><p>hmm.. either you're a genius or I'm a idiot... oh well <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>blackTT55</b> »</i></TD></TR><TR><TD CLASS="quote">hmm.. either you're a genius or I'm a idiot... oh well <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> </TD></TR></TABLE><p>i will just assume i got lucky <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Discussion Starter · #14 ·
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>phuz</b> »</i></TD></TR><TR><TD CLASS="quote"><p>i will just assume i got lucky <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"></TD></TR></TABLE><p>next up is brake pads... can't wait to see how this goes... <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0">
mine took all of about 10 minutes from start to finish.<p>You just have to contort your body a little bit under the glove compartment.<p>Brakes won't take more than 40 minutes per side.
1 - 16 of 16 Posts
