I have 2 issues on my 2006 C70 that may or may not be easy fixes for you guys but I need help with them.
First, my horn has given out. Not sure I it's a wiring/fuse problem but the horn doesn't work when I hit the middle of the steering wheel. Any suggestions and how-to's?
Second, my 12V plug in my center console doesn't provide power anymore. I always left my iPod dock/charger plugged in so maybe that caused the problem? Or, maybe it's a fuse/wiring issue but I'm not sure so I thought I'd ask if anyone else on here has had similar problems. Suggestions/how-to's?
Let me know what you guys think I should do
I'd check the fuse for the plug. One of my former cars had one that didn't function and it turned out to be a blown fuse. Easy fix.
I Know for a a fact the Second problem is a fuse. might might not be check the fuses. and horn may also be a fuse if not also give it out a check.
Under the hood, Fuse 20 for the horn. 15A.
Below the glove box, Fuse 45 for 12V. 15A.
If you're blowing so many fuses, I would be watching for other signs of electrical problems.
Wise to check the voltage level.
