1 - 8 of 8 Posts
This morning my check engine light came on and I hear a rushing air sound from the area of the inter cooler to turbo pipe, so I suspect the rubber hoses at the turbo and inter cooler ends. But does this typically make noise when it fails? I'm at work and haven't dug too deep yet.
I am here: http://tapatalk.com/map.php?3wdfqv
Just check the hose coupler, it may have a whole in it or just blew off the coupler. Mine blew off, I just cleaned the oil off, reattached the hose and made sure it was tight and it's fine now. If the piping seems ok then start looking at the endtanks on the intercooler there maybe a crack in it.
did you change the stock hose? it looks that someone did use ziptie on that hose, i wondering what else did he change.
It did appear to have been zip-tied. I suspect that sometime in the past when the car was in for service the split was noticed and zip-tied rather than replaced. I bought a length of generic vac hose to replace it.
I am here: http://tapatalk.com/map.php?mzlslh
Someone correct me if I'm wrong, but I believe that hose is zip-tied from the factory either that or there's a TSB on that hose and the dealer put a zip-tie on it b/c mine currently has that hose zip-tied.
no its not. It comes with factory clamp.
1 - 8 of 8 Posts
