1 - 6 of 6 Posts
· Registered
I'm throwing the 2-3-2 code, and have been for about the last week now. I keep resetting it, as I haven't had the time to more deeply look into the problem and I hate seeing that check engine light on. Here is my question for you all. Has anyone dealt with this problem before? I inspected the vacuum lines and found one with a slight leak, but I replaced it last night, only to get the code again this morning. I have thermal wrapped the downpipe (stock), so is it possible that I'm overheating the O2? The only other thing I've changed is I replaced the factory air filter with a K&N unit, but I seriously doubt that has done anything. Thanks for your help!
· Registered
You may have a leak in the IC or in the hoses connecting the turbo to the TB. It will suck air during idle and leak boost during load. Also check the IAM and hoses. They have been an issue for many.
Cheers
Prospero
1 - 6 of 6 Posts
