**SOLD**
1998 Volvo V70R
Silver exterior with black/charcoal alcantara interior
158xxx miles
AWD automatic 2.3l turbo
Location: Boston Area (can deliver or meet semi-locally)
Contact: [email protected] OR text: 781 710 six three eight six
Price: $2300
For sale is my 1998 V70R. I have had the car for 3 years and have kept the car up to date with replacement parts and care. The car has low miles for the year and the engine shows no signs of problems at all. I have changed the oil every 3000 miles with an OEM filter and Mobil1 10w30. Where possible, only OEM replacement parts have been used. The exterior of the car looks great for its age and has some touch-up paint applied however, it is a 17 year old car and shows age. The engine has been maintained meticulously and maintains OEM compression. The turbo is original and does not leak oil. The AC works flawlessly. Summer tires still have life but should be replaced next season. The car recently passed inspection in Massachusetts. There are no check engine lights/codes and the title is clear.
The car is a great runner and has lots of life left. It handles great with the working AWD system in-tact and is comfortable driving across country or daily driving. Selling as I bought a newer Volvo.
New parts in the last 18 months:
BODY
ABM Projector headlights with HID bulbs and replacement foglights with Lamin-X on both (protective film) – Amazing light output
OEM bumper inserts
OEM cross-bars
OEM Volvo Comet 16” Wheels
XC Front Grill
SUSPENSION
OEM sub-frame mounts
OEM all 4 wheel bearings
Front lower control arms
Front sway bar end links
OEM engine mounts (all 4 including upper)
OEM front shocks, mounts and shock bearings
BRAKES
Front brakes upgraded to OEM 302mm with non-metallic pads for low dust
Rear brakes OEM rotors and pads
Replacement e-brake cables
OWM e-brake assemblies
Full brake fluid flush
ENGINE and TRANS
OEM spark plugs
OEM PCV system
OEM cabin filter
Performance air filter
IPD boost controller
OEM throttle cable
OEM Complete timing belt and water pump (including tensioners and bearings) – less than 2000 miles ago
OEM Serpentine belt
OEM Coolant overflow tank and cap
Vacuum hoses replaced with silicone
OEM seals at the transmission and oil cooler lines
OEM Cam seals
OEM PNP switch (trans control)
OEM Thermostat
OEM Water Temp Sensor
DRIVELINE
OEM Axle seals
Bevel gear rebuilt (All OEM Seals – Mobil1 Trans oil)
Transmission fluid replacement with Mobil1 3309 – shifts perfectly
Both front rebuilt axels
Replacement rebuilt prop shaft
Lower mileage replacement viscous coupling
Replacement steering rack
INTERIOR
Working SC-900 radio and 3 disc changer
Integrated audio connection
Rear sun shade
Weather-tech floor mats and rear cargo liner
Passenger side map pocket
Replacement heater core
Steering bearing
OEM Walnut trim (original Aluminum will be included)
Wear on the driver side seat bolster (no rips or holes)
There are a few issues currently with the car that should be addressed:
Traction control activates occasionally; could be an issue with a wheel speed sensor which are cheap replacements. ABS/TRACS light is on and the ABS power was unplugged
Rebuilt steering rack is weeping slightly
Vibration at 65 mph on the highway – driveshaft was newly rebuilt but may be mis-aligned. Tires are not bent and have been balanced.
Ignition switch is failing but still works fine (doesn’t spring back)
Contact me for additional questions or details.
1998 Volvo V70R
158xxx miles
Price: $2300
BODY
OEM bumper inserts
OEM cross-bars
XC Front Grill
SUSPENSION
BRAKES
ENGINE and TRANS
OEM spark plugs
OEM PCV system
OEM cabin filter
OEM throttle cable
OEM Serpentine belt
OEM Cam seals
OEM Thermostat
DRIVELINE
OEM Axle seals
INTERIOR
Rear sun shade
Steering bearing
