1 - 2 of 2 Posts
I had to replace the fuel pump at 180,000 due to leakage and noise. From experience I purchased a Volvo fuel pump; this pump then failed at 192,000 so I sent it in on warranty (FCP, the Best)
and purchased the identical pump which I just installed.
However, when hooking up the plugs I find that this pump has one extra connection that I cannot find a mate for anywhere so I am asking if someone can help by letting me know either where the
plug goes, or if it is not used on my model. The plug to which I am referring is the WHITE one, a single male connector with a BLACK wire going to it, in the center of the photo between the two black plugs.
Many Thanks in advance.
Im not completely sure on a 98 wagon. But if your referring to the center white plug with the round connection,,there should be a round female plug next to where you plug the pump wiring plug into the harness in the Wagon. I think its a ground but not entirely sure.
1 - 2 of 2 Posts
