I am stumped with the left rear door on this car. It will always lock either from the front driver's switch or from the key fob, but neither will unlock the door. I thought for sure after messing with it that the door lock was bad so I got another door lock which works perfectly fine, put it in, but the same exact problem.
Any ideas for this stumper? :angryfire:
When you hit unlock does it at least *try*? Or is it total silent nothing
If it tries but just can't "get it up" then it's just a bad actuator, and the replacement you grabbed is bad too, very common. If it doesn't even try, then it's a wiring issue
I have the same problem on the same door as well as the rear hatch latch. Interested to see what you find out.
