Re: 1998 V70 XC IN NEED OF HELP!! (pcf817)
Quote, originally posted by pcf817 » |
...ALOT of sentimental value.... If you're in college why is it you can't spell? A LOT TWO WORDS 1) Replace Ignition Coils 1 COIL ON A 98, VERY EASY 2) AWD Seal and Transmission Differential are starting to go WHAT IS A TRANSMISSION DIFFERNTIAL THE BEVEL GEAR? 3) Cowling drain holes--Clogged 10 MINUTES 4) Air Intake needs to be overhauled HUH? 5) Timing Belt replacement NOT THAT HARD TO DO, A COUPLE OF HOURS IF YOU HAVE TALENT 6) 'Struts and/or Axle need work'--Alot of clanking sounds going over bumps, clicking sounds turning the steering wheel SWAY BAR LINKS TO START WITH, COULD BE SPRING SEATS, COMMON ISSUES 7) New Brakes AEE ABOVE 8) New Hand Brake PIA JOB TO DO A TOTAL REBUILD |
