totally agree - has to be something i did to cause the issue. I managed to take a running car and turn it into a non-running car! i'll respond to each of your suggestions - hopefully we can figure this out!
So the high idle disappeared once you found and fixed the disconnected tps but it still runs rough after resetting the ecu? Does it stay running on its own long enough to throw a code? ---> correct, the high idle is gone. when the MAF is connected the engine runs for like 2 seconds and dies. But when the MAF is disconnected, the engine does idle but not very well.
Were the fuel injector orings in good shape and you used one on ea side? ---> replaced the o-rings, 2 per injector. Also replaced the basket filters and pintle caps.
You certain you have the ignition sys aligned with the firing order? Did you replace the dist cap and rotor? ---> replaced the cap and rotor exactly how it was on the vehicle before. will check again to be certain.
If you disturbed the ecu, assure it’s connection pins are not bent. ---> i didn't see anything out of the ordinary. will check again to be certain.
Did you replace the spark plug wires? If not confirm no high resistance exists in each cable when bending each one around. Include the coil wire in your checks. ---> replaced the plugs (genuine volvo) and wires (bougicord) in the proper order. will check again to be certain.
Check every vac hose including the hose from the turbo inlet pipe down low to the RH side where it hits the fuel pres reg near the steering rack. And the vac source elbow in the pcv circuit on the RH side of the intake man. Make sure that’s not flopping around. ---> this could be part of the issue. will check again and take pictures to see if anyone can see something incorrect.
If your model has the sas emissions system, check the entire circuit’s hoses and lines for cracks to include where the valve connects to the exhaust stream and also look upstream at the air pump and its connections to the air box. You may have bumped parts of it while working in there. ---> this could also be part of the issue. i replaced two of the hoses on the evap line (mentioned earlier in my thread) from the t-connector to the check valve and then on to the bottom of the turbo inlet pipe. will check again and take pictures to see if anyone can see something incorrect.
I’m assuming you’ve pretty thoroughly ruled out an electrical short in the various sections of the harness you were working with. Easiest way is to move things around to see if the motor’s idle improves. ---> agreed, i moved harnesses around and did not notice any changes.
If the motor ran fine before the service you did it must be something in front of you under the hood causing the rough idle. Something like a maf does not just stop working. ---> agreed. MAF was working fine prior to me working on it and stored safely on the workbench while out of the vehicle. but since the engine idles differently when the MAF is connected/disconnected, I'm assuming the issue is airflow somewhere in the system.
