1 - 20 of 151 Posts
Discussion Starter #1
hey everybody - fairly new to the volvo scene but have been browsing the forum for a few years now. first got introduced to volvos by my girlfriend who had a sweet 850r back in the day that she never stops talking about! i never got to see it in person because she traded it for a lexus before we met, but just talking about it got me pretty hyped about getting my first volvo project.
so about four years ago i bought a 1998 V70 T5 with 140k miles for $1500 out in CA. it was bone stock, original white paint, had a loud squeak coming from the passenger front side, but other than that in great condition. the owner said his daughter drove it in college and he didn't have much need for it anymore. plus the dealership quoted him way too much $$ to find out the issue and fix it, so he was ready to deal it for a low price! got it home, replaced the tie rod and bushings, problem solved for like $30 in parts. score!
this build thread is starting like mid-build because i've already done a few things over the past couple years - lowering springs, rims/tires, tint, paint, and some minor mechanical fixes. but i've decided to turn it into my daily driver, so i'll be upgrading a few things in the next month or so and wanted to document my progress!
future plans aren't too crazy but include:
*k&n intake
*silverstar ultra headlights
*bilstein shocks
*msd ignition
*bosch distributor cap/rotor
*genuine volvo plugs
*bougiecord spark plug wires
*brakes - rotors/pads
*engine mounts
*turbo boost gauge
general maintenance:
*oil/filter
*cabin air filter
*serp belt
*coolant hoses
*fuel filter
*water pump/tstat
*brake fluid
*trans drain/fill
*inspect turbo
*pcv system
*parking brake
*anything else i find along the way
i'm going to need some help along the way, and i'm open to all ideas and suggestions. so please follow and comment! current pictures to come shortly!
Discussion Starter #5
Welcome to the forum. Your pictures didnt seem to load. Try uploading them to a site like imgur.com The copy the BBC code option and paste the links.
Thank you! Still getting the hang of it!
No worries, a lot of knowledge here to help you along the way. You may not get a ton of responses to you questions, but the responses you get will be sound from hardcore enthusiasts
And you may want to update your profile on where you live, helps locating local guys you can network with
Couple suggestions.
Skip the K&N intake the maf doesnt like the oiled filter. A snabb intake pipe and a good stock filter is the proper upgrade.
E codes or jewels for the headlights bot of which do very well with LED
302mm brakes
e
Discussion Starter #9
Couple suggestions.
302mm brakes
e
ah man, i've already got the k&n intake and stock size brakes. will the k&n for sure have problems?
It will kill the maf with the oil from it
1998 V70 T5 with factory m56h; 18t, Green injectors, 50% e85
Not my experience, but I alternate filters, allowing plenty of time for the oil to evaporate before use. Just don’t over-oil.
Discussion Starter #12
appreciate you sharing your experience - i've had k&n filters in every other vehicle i've owned and never run into any issues. but, this will be the first volvo, so i got kind of nervous when hearing it may cause maf problems. i'm happy to hear it should still work as long as i make sure not to over-oil!
Discussion Starter #13
OK so getting started this weekend! here's the plan... since i need this car to be my daily driver sooner rather than later, i'm going to start with everything that makes it run/drive safely. it has basically just been parked in the garage and rarely driven the past couple years, so i'll need to go over everything mechanical first before starting any aesthetic mods. i started my own checklist, but if anyone has some suggestions on what else to specifically look at, please chime in!
*replace fluids - oil, trans, coolant, wiper, power steering, brakes, a/c, fuel
*replace filters - oil, fuel, air, cabin
*replace plugs, wires, distributor cap/rotor
*replace timing belt, tensioner, pulleys, serp belt
*replace brakes - rotors/pads
*check/replace hoses - radiator upper/lower, pcv system, turbo lines, oil cooler, coolant reservoir, brake lines
*check/replace mounts - engine/trans
*check/replace oil pump, fuel pump, water pump, tstat
*check/replace steering components - inner/outer tie rods, cv joints, boots
*check/replace gaskets & o-rings
*general cleaning under the hood
Discussion Starter #14
Finally got my workspace all organized and ready to get started. Always seems like there are multiple projects before even starting THE project.
Discussion Starter #15
Oh boy... I've got my work cut out for me. Stupid Arizona dust storms... Only left the car outside a few different times! Gonna need some serious cleaning in addition to everything else.
Discussion Starter #16
First of many knuckle-busters.. I don't understand how people can wear gloves while working under the hood. I've tried so many different kinds and they always seem to get in the way. Anyone have a pair they really like?
Discussion Starter #17
Got the valve cover off and noticed some fluid. Would that be a leak or over-poured engine oil that seeped down in there?
Discussion Starter #18
Removed the battery/tray, air filter assembly and air ducts, turbo pipe, and upper rear engine mount. Also, got some cleaning done. Didn't have a lot of time today but got a good start.
Got parts on the way to get me going:
-pcv kit
-distributor cap/rotor
-plugs/wires
-fuel filter
-cabin air filter
Discussion Starter #19
does anybody have any feedback on the upper engine mount (poly vs rubber) ? i'm not a fan of engine vibration, so i'm leaning towards sticking with rubber, but open to suggestions, pros/cons
1 - 20 of 151 Posts
