Hey SS, got a quick question. I'm looking to replace the engine cradle on my 97 R and was wondering if anyone had an idea which one it is? I saw some options for the cradle are either 2 or 4 bolt? Any insight would be helpful. My car is an automatic and of course, FWD.
Thanks!
I think the two bolt/four bolt is referring to the moutings for the control arms on the subframe. Yours being a FWD use the two bolt comtrol arms.
Awesome, thank you so much!
And do you know if the s70 is the same or not?
98 should be the same, can't confirm 99-2000 but if it's fwd then it should be the same
Awesome, thank you buddy!
You should try to find one from a C70 convertible. That will have aluminum subframe bushings and try to get the undercarriage braces that they came with to stiffen up the convertible chassis. It bolts right up onto FWD cars (not AWD cars unfortunately).
