1 - 2 of 2 Posts
I had to temporarily remove (and unplug) the passenger side forward airbag. While I had it removed, I had to crank and move the vehicle. Obviously, this set a code in the SRS system and the light remains on even though I have reinstalled everything. I have looked everywhere trying to find the reset/memory clear procedure, but have had no luck. The closest (to my year model) procedure that I've been able to find is for a 1994 Volvo 960, but this is not the same setup. I'm guessing that somewhere in between 94 and 96, volvo integrated the OBD II system that my car has. I have an OBDII scanner and hooked it up. Though no codes were showing, I cleared the OBDII memory. However, this did not turn out the light. I also removed the battery cable for a few minutes, but this did no good. Could someone PLEASE tell me how to successfully clear the memory to turn off the SRS light? HELP would be very much appreciated!
Re: 1996 Volvo 960 SRS light is on (aeroron)
Welcome to Swedespeed, Ronnie.<p>Without a Volvo dealer visit, about the only light you can kill on the '96 960 is the service engine light behind the little black rubber plug in the dash.<p>Here are two leads to chase...<p><A HREF="http://forums.swedespeed.com/zerothread?id=21465" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=21465</A><p><A HREF="http://forums.swedespeed.com/zerothread?id=45293" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=45293</A><p>George Dill<p>
1 - 2 of 2 Posts
