1 - 2 of 2 Posts
Hi all,
I'm having troubles with my wagon today. I went into the store to do some shopping and when I came out it started and revved to 2k normally, settled down to 1k, idled badly, then died. It took a little cranking and some gas to get it to start again and I tried keeping it alive with the gas pedal but it would just idle sporadically and die. I can hear the fuel pump priming when I turn the key. I had a couple of extra fuel pump relays from the junk yard in the glovebox and I tried those out to no avail. I unplugged the MAF as well, but that didn't work either.
Tomorrow I'm going to clean the throttle body and the IAC. The PCV system has been done recently, but I also just found that I didn't connect the crankcase tube very well as it was off the engine, so I reconnected it about a week ago. I did notice that my distributor cap didn't look all that great when I had it off the car recently. I guess I didn't try jumpering the fuel pump relay contacts either. Can you think of any other places I should look to figure this out? Thanks for any help.
Just curious, but how did this work out? Only asking cuz my IAC caused my 95 manual to stall when it was cold and when I took it out and cleaned it, the problem immediately went away... Very gratifying! But I do like to know other solutions to these kinds of issues for the future as I think most of us do...
1 - 2 of 2 Posts
