1 - 20 of 33 Posts
1995 850 T5-R Flat Black Very Modded and Fast
1995 Volvo 850 T5-R with 180,000 miles, never wrecked, very modified.<p>I bought it in '05 from Don Struke in Baltimore For $6500 and have done this with it,<p>-Engine- Stock block, NA cams w/ QBM cam dial, New radiator, New heater core and hoses, Blue SAMCO coolant hoses, New water pump, New timing belt and rollers and tensioner, New altenator, New serp belt, Unorthadox racing underdrive pulley, S60R exhaust manifold ported and polished opened up to a t3 outlet 10mm studs, New HAHN Racecraft Super 16G turbo, Custom all Mandrel SS 3" exhaust own pipe has 1 SS flex bellow and a 2 bolt flange into a round borla XR1 muffler into another flex then some pipe into a magnaflow resonator then over the axle and another 2 bolt flange into an oval borla XR1 muffler out to a gibson rectangle polished tip, All custom aluminum intercooler piping 2" hot side 2.25" cold side w/ all blue silicone connectors and t-bolts, 24x10x3" bar and plate front mount intercooler w/ 2.25" inlet and outlet, HKS SS BOV, Ported intake manifold w/ NA 850 throttle body w/ 960 throttle plate, New FPR, Walbro 255lph pump, New fuel filter, S60R 465cc green injectors, Crank case breather kit recently replaced and plumbed into a catch can, BMC carbon fiber canister filter, New MAF, Custom 2.75" aluminum intake pipe, MSD coil, OE cap/ rotor/ wires, Bosch Copper plugs gapped to .022, All new mounts/ front and rear hydraulics/ upper firewall poly reinforced and yellow poly/ new lower side mount/ ipd poly trans mount, Greddy profec B electronic boost controller, Greddy turbo timer, Optima yellow top in trunk w/ super thick I forget the gauge welding cable run to the front, 22psi, Custom tuned ECU for all my mods. I would say it has around 300 wheel HP but it really needs to be dynoed.<p>-Transmission- 96 M56H with a Quaife LSD and Brass shift forks, S60R clutch, EST short shifter w/ delrin bushings and a Momo boot w/ Sparco knob, Sparco pedals.<p>-AC- New everything, Compressor, Drier, Condenser, Evaporator, Low Pressure switch, High pressure switch, Self adjusting orface tube, Added a 10 pusher condenser fan, Rockin AC blows super cold.<p>-Suspension- Koni Yellows, Ipd springs cut fronts, QBM adj. sway bar endlinks, Stock t5-r sways, New OE right side control arm, New tie rod ends, Reinforced subframe mounts with polyurethane, Replaced upper strut mounts, Ipd strut mount brace, Just had a recent performance alignment.<p>-Brakes- Just replaced all four calipers with rebuilt ones painted red, EBC red stuff pads, Power slot rotors, SS lines up front, New volvo rear lines, Synthetic DOT 4 fluid, 2 new E-brake cables and shoes.<p>-Wheels and TIres- Titans painted gloss black with Brand new 215/45/17 Nankang NS1's, I have a set of FK 10mm spacers uninstalled that goes with, I have 2 more flat black Titans that will go with i planned on these for racing tires, or use one as a full size spare.<p>-Lighting- Halo HID foglights in yellow one of the ballasts are burnt out right now, Stock headlights with some of the chrome painted black Sylvania Silverstar bulbs Hi and Lo, Smoked turn signals with the writing smoothed out, Side markers smoothed and smoked wired to blinkers, Stock tails smoothed gray painted black and clearcoated over it all.<p>-Paint- Just repainted every piece of this car in Jan. of this year using PPG paints and clears, The roof is gloss, center of hood gloss, tops of bumpers/ side trim were sanded and polyester primed to make smooth and glossy, On the trunk in between the taillights is gloss, Mirror caps are gloss, Ipd mesh grill painted to match the glossy part of hood, The rest of the paint is basecoat/ clearcoat using ppg flexed and flat clearcoat, I took all the seals out of the windows, Took the hood/ trunk/ bumpers/ rockers/ mirrors/ handles/ trim off, Very professional and meticulous paint job, Some of it has taken a beating like any DD especially on the highway some chips here and there on the front, can be touched up if deal is sealed with buyer.<p>-Windows- Just had the windshield replaced right before paint due to a crack, Every window is tinted, Windshield is 35% and all the other windows are 15%, Its very dark and the windshield tint might have to turn into a sun strip depending on the law.<p>-Stereo- New Eclipse HU w/ ipod controller HD ready, Polk momo 5.25 components up front/ woofers in doors tweets in dash/ wired to a profile 300w amp, infinity kappa 5.25 rear door speakers powered by HU, Polk momo 6.5 components in custom made rear deck of 1/8" masonite and covered with black carpet I even built little boxes for the woofers/ powered by a polk momo 300w amp, 10" polk momo sub powered by a 500w polk momo amp, Sounds amazing to me.<p>-Interior- Drivers seat has wear as shown in pics , All other seats in excellent shape they all work, Steering wheel suede is a little worn too, Door panels and pockets and handles etc all in excellent condition, Dash is amazingly in awesome shape/ when I had it out to do the evap I checked everything and reinforced with jb weld and sound dead stuff but the pass airbag cover still has the typical lift and the very front black piece has its few cracks, Carpets and mats are like new, Everything else works and is in good shape, Maybe a few burnt out switch bulbs, Speedo reads off and so does odo I had to tap into the abs to get a signal because I have a '95 with a '96 trans, Cruise does not work since manual swap, Very comfy and cold and solid, The trunk has FatMat asphalt sound barrier all over the floor and lid and then I have Edead liquid stuff painted on top of that and everything else, Its nice, Head liner is in great shape no sag at all, I have the aluminum R lock knobs, I put the boost controller HU and turbo timer in the spare vent on the left side of dash, its perfect, I also have a gray 3 gauge a- pillar from ipd uninstalled included.<p>There is absolutely nothing wrong with this car, I would drive it anywhere, and I have back in '05 I drove it all the way to Seattle and back seeing the country. The only thing I would do (which I still might if I have it a bit longer) is water injection/ wideband/ a 3rd gauge to fit my pod, fix the fog light, get it dynoed, and run it at the track.<br>I am selling this car for financial reasons only, I love this car but it is not necessary for me anymore and actually has become a burden for me to keep it so I hope it goes to someone who appreciates it and will take care of it and take it farther, it is an ultimate Daily.<p>Asking 7,750 OBO, <p>Car is in St. Augustine, FL 32080, I have the clear title in hand. <br>Call for more info (904) 377-1432<br>Thanks,<br>Jeremy<p>Rest of pics here<br><A HREF="http://s650.photobucket.com/albums/uu230/jeremycooney" TARGET="_blank">http://s650.photobucket.com/al...ooney</A>/<p><IMG SRC="http://i650.photobucket.com/albums/uu230/jeremycooney/DSC00216.jpg" BORDER="0"><br><IMG SRC="http://i650.photobucket.com/albums/uu230/jeremycooney/DSC00214.jpg" BORDER="0"><br><IMG SRC="http://i650.photobucket.com/albums/uu230/jeremycooney/DSC00172.jpg" BORDER="0"><br><IMG SRC="http://i650.photobucket.com/albums/uu230/jeremycooney/DSC00166.jpg" BORDER="0"><br><IMG SRC="http://i650.photobucket.com/albums/uu230/jeremycooney/DSC00162.jpg" BORDER="0"><br><IMG SRC="http://i650.photobucket.com/albums/uu230/jeremycooney/DSC00168.jpg" BORDER="0"><br><IMG SRC="http://i650.photobucket.com/albums/uu230/jeremycooney/DSC00220.jpg" BORDER="0"><br><IMG SRC="http://i650.photobucket.com/albums/uu230/jeremycooney/DSC00213.jpg" BORDER="0"><p><i>Modified by jeremycooney at 6:08 AM 7-29-2009</i><p><br><i>Modified by jeremycooney at 8:56 PM 8-11-2009</i><BR><BR>
<i>Modified by jeremycooney at 4:46 PM 8-12-2009</i>
Re: 1995 850 T5-R Flat Black Very Modded and Fast (jeremycooney)
As I wa starting to read this, I was all redy to make one of my comments...<br>I can't, this is pretty neat even in a Volvo! <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <br>I'm a street rodder but usually hate satin finishes, but this looks pretty neat <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <br>Good luck with your sale<p>EDIT: You need to clean that engine comp. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <br>(I had to find something wrong with it!) <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
It looks great... that tint won't fly in most states... especially the front windshield.<p>LOVE the Matte Black...and it is tasteful in it's sinister look. Good luck.
Re: (SeventyR)
Easy enough to remove and the OP really should remove it.<br>Fl may be one of a handful of states that allow it
2021 Inscription Recharge - 2021 Silverado LTZ 6.2L
I can think of one thing it needs.... fuel. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
Re: (kenhoeve)
two things but they are easy for the future owner IPD black headlights and taillight tint again very nice car bump.......
Re: (volvosince16)
Damn you took those pics by FA's and 16th street!!! That used to be my old surf spot when I lived in Gainesville when I was in high school. My buddies and I used to drive over every weekend to go surfing!!! Brings back a lot of memories before they dredged up all the sand and made it a beach there, at least there was a beach there last time I saw it. Anyways, kick a$$ car man, good luck in the sale!!! My dad my be interested, he lives in Gainesville still and was looking for a 850R or a T5r. You wouldn't be willing to trade a really nice old 544 would you??
I really would like to buy this... "thing"... but what would an old 65 years old Jewish guy be doing driving something like this?! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/sly.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <p>I drove that other yellow T5R manual conversion that was for sale a year ago, (also with a Quaife), I have to admit, it <I>was </I>fun
Re: 1995 850 T5-R Flat Black Very Modded and Fast (JRL)
Go for it Jim you only live once <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0">
Is mileage just on body? How many miles on Motor / Trans? Any rust? Saw photo of dash - Is passenger airbag installed?<p>I'm looking for a fun car as a daily driver.
I almost bought this car from Don here in Baltimore. .... it was rather quick then, & in great shape. Can only imagine how much fun it is now ! <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <p>Good luck with the sale...<br> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">I really would like to buy this... "thing"... but what would an old 65 years old Jewish guy be doing driving something like this?! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/sly.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> </TD></TR></TABLE><p>Jim...I can totally see you in this. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/cool.gif" BORDER="0">
Re: 1995 850 T5-R Flat Black Very Modded and Fast (SeventyR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>SeventyR</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Jim...I can totally see you in this. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/cool.gif" BORDER="0"> </TD></TR></TABLE><p>Naaaaaw....<br>That's a young man's hot rod Volvo, I'm too old to drive around in something like that..<br>(as much as I like it)!
I'd take this over my s40<p>Gotta love murdered Volvos. <p>*Sigh* wish I could get it
Discussion Starter · #19 ·
Re: 1995 850 T5-R Flat Black Very Modded and Fast (zeedragon)
Engine and body are the same mileage 180k, trans is unknown, I have about 20k on the LSD. No Rust Anywhere.<p>Thanks
1 - 20 of 33 Posts
