Selling my 1983 Volvo 242DL. Freshly repainted in the original Scotia Blue as of April 2015. The bumpers and trim were removed prior to being painted. It had the passenger side rocker replaced with a German part due to minor very rust. Engine is a B23F with an M46 manual transmission. The overdrive works well. The shifter bushings are worn, but new ones are included with the sale. Runs and drives well. Unsure as to the actual mileage as I have replaced the speedometer several times in the past 12 years or so. Rare Webasto sunroof. It is said to be one of 8 built with this sunroof as a "concept" car. This was information I was given by a local Volvo dealer in 2002. It was a "special delivery" car, and lived the first part of its life in Germany. No factory AC. Never had it from new, as in it was built without air conditioning from the factory. Nothing was removed. Has factory power steering, however. Just tuned; new plugs, cap/rotor, air filter. Turbo sways, IPD overload rear springs, Virgos, and a bunch of extra parts. Good tires. Car is in dry storage, not sitting outdoors in the weather. Has been a part of the family on and off for a long time. I have a 1-year-old son who takes my time and attention, so the car must go.
Partial list of parts included with the car (not all parts are pictured):
Used parts:
ECU
Cylinder head
Trim
Tail lamps
1984 B23 engine (ran well when pulled in August 2015); wiring harness NOT included
Distributor
Ignition module
Window regulators
Entire set of glass minus windshield with proper date codes
Instrument clusters and parts
Mirrors
Sun visors
Exhaust manifolds
Timing belt cover
Books
Passenger door panel
Boxes and boxes of misc. parts
New parts not installed:
Timing belt
Front engine seals
Fuel filter
Shifter bushings that were not cheap from Volvo
Box of misc. new parts
Recent service/work/replaced parts:
Timing belt (Contintech)
Belts (Contintech)
Flame trap and hoses
Heater hoses
Throttle housing cleaned and adjusted
Air filter (Mann)
Oil change (always Mobil 1 10w30 fully synthetic and Mann filters)
In tank fuel pump
Main fuel pump (new Bosch)
Plugs (Bosch copper)
Plug wires (Bosch)
Cap and rotor (OE)
CO adjustment
Coolant change (Prestone)
Rear axle oil change (synthetic Mobil 1 75w90)
Transmission fluid change
4th gear contact switch for overdrive on transmission
Entire exhaust from header pipe to tailpipe (starla)
Exhaust manifold gaskets
O2 sensor (Bosch)
Sylvania super headlights
Valve cover gasket
At least one U joint
Rear seat belt covers (reproduction from eBay... not cheap)
Rear hat shelf vent covers from Volvo
All new trim clips on the body after repaint
Of course the new Scotia Blue paint and body work
Located in Newark, Delaware 19702. Selling the car as is. First $3650.00 cash takes the car and everything with it.
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/30354D18-ACF1-418E-8BBE-9328E109257D_zpslxokisbd.jpg" border="0" alt=" photo 30354D18-ACF1-418E-8BBE-9328E109257D_zpslxokisbd.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/F44DA9CE-91C5-499E-9431-D1003730C326_zpsq4xvsztr.jpg" border="0" alt=" photo F44DA9CE-91C5-499E-9431-D1003730C326_zpsq4xvsztr.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/4E2CC255-DC74-4C52-91BC-227AE07C2247_zpsvctnt9cx.jpg" border="0" alt=" photo 4E2CC255-DC74-4C52-91BC-227AE07C2247_zpsvctnt9cx.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/EFFE940C-8F1C-4F45-86F4-8D412C2908CA_zpsoliqx4uc.jpg" border="0" alt=" photo EFFE940C-8F1C-4F45-86F4-8D412C2908CA_zpsoliqx4uc.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/693F5B00-14D9-4A71-B663-05E16EF5E709_zpsvo2yps7c.jpg" border="0" alt=" photo 693F5B00-14D9-4A71-B663-05E16EF5E709_zpsvo2yps7c.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/F0DB2075-4AE6-49F5-BFA4-8F839225144D_zps6wm9unhm.jpg" border="0" alt=" photo F0DB2075-4AE6-49F5-BFA4-8F839225144D_zps6wm9unhm.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/EB7C4BA9-C9B6-476C-AB5F-0904A73FF94A_zpshyyutclg.jpg" border="0" alt=" photo EB7C4BA9-C9B6-476C-AB5F-0904A73FF94A_zpshyyutclg.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/8CC61803-DAAA-4132-B39F-56FCB52F4253_zps7rb6mf3a.jpg" border="0" alt=" photo 8CC61803-DAAA-4132-B39F-56FCB52F4253_zps7rb6mf3a.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/C1EA7AD1-93DC-43AC-841B-7DE9F8954D63_zpslcgjyxdi.jpg" border="0" alt=" photo C1EA7AD1-93DC-43AC-841B-7DE9F8954D63_zpslcgjyxdi.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/253B419C-80A3-4730-8188-98DE6A28B240_zpsztrflnf9.jpg" border="0" alt=" photo 253B419C-80A3-4730-8188-98DE6A28B240_zpsztrflnf9.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/90C4F0D6-E147-4879-9B31-67EA3CCFFACB_zpswow4rtjm.jpg" border="0" alt=" photo 90C4F0D6-E147-4879-9B31-67EA3CCFFACB_zpswow4rtjm.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/7248E074-74BE-4BCB-8A0A-81D58DAF4ED7_zpscjxadkoa.jpg" border="0" alt=" photo 7248E074-74BE-4BCB-8A0A-81D58DAF4ED7_zpscjxadkoa.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/34E48FC3-5D3A-4E9B-BEB3-CA1E9CAFEB5A_zpsmqy9dyli.jpg" border="0" alt=" photo 34E48FC3-5D3A-4E9B-BEB3-CA1E9CAFEB5A_zpsmqy9dyli.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/C2AE5A76-6707-416F-A2C7-AE09A11EAD87_zpskb77wvaj.jpg" border="0" alt=" photo C2AE5A76-6707-416F-A2C7-AE09A11EAD87_zpskb77wvaj.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/742679A4-32D6-41DB-8D6E-E11A6564249F_zpswyntd7lj.jpg" border="0" alt=" photo 742679A4-32D6-41DB-8D6E-E11A6564249F_zpswyntd7lj.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/62F4AB05-1356-487A-AB80-0B828A314C50_zpsx7xw7t5j.jpg" border="0" alt=" photo 62F4AB05-1356-487A-AB80-0B828A314C50_zpsx7xw7t5j.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/1E2906C6-9520-4AA5-A386-CD2F0D7DC1E0_zps4sp7qatp.jpg" border="0" alt=" photo 1E2906C6-9520-4AA5-A386-CD2F0D7DC1E0_zps4sp7qatp.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/E64E3DA3-39F8-443F-B62A-CBFF601A4202_zpsvlp7eh7x.jpg" border="0" alt=" photo E64E3DA3-39F8-443F-B62A-CBFF601A4202_zpsvlp7eh7x.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/AB393898-5A06-4B01-A2E7-A27735D1AAF7_zpsvmlckseg.jpg" border="0" alt=" photo AB393898-5A06-4B01-A2E7-A27735D1AAF7_zpsvmlckseg.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/9AF45B41-0ABD-42BE-8FF5-93887B588519_zps7lanmwa5.jpg" border="0" alt=" photo 9AF45B41-0ABD-42BE-8FF5-93887B588519_zps7lanmwa5.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/CD9F3C06-4AE6-41EB-B449-E55E2302E7AE_zpste1unair.jpg" border="0" alt=" photo CD9F3C06-4AE6-41EB-B449-E55E2302E7AE_zpste1unair.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/7424BF6C-4C50-4CFB-BFA1-AD9C136702E5_zpsi5qfp5f1.jpg" border="0" alt=" photo 7424BF6C-4C50-4CFB-BFA1-AD9C136702E5_zpsi5qfp5f1.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/E64C76EF-6AC3-4422-BE7A-6FD4AC97DCA5_zps152qcqf0.jpg" border="0" alt=" photo E64C76EF-6AC3-4422-BE7A-6FD4AC97DCA5_zps152qcqf0.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/14E9A999-3847-4F1E-BD2A-E52EB0FDC914_zps1yi1npix.jpg" border="0" alt=" photo 14E9A999-3847-4F1E-BD2A-E52EB0FDC914_zps1yi1npix.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/BD5F969B-FCEA-4CC3-9D17-B986B9233AF3_zps2z1ssfdv.jpg" border="0" alt=" photo BD5F969B-FCEA-4CC3-9D17-B986B9233AF3_zps2z1ssfdv.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/962B1A7D-663C-4BB8-84D9-340757D43836_zpswuiuogg5.jpg" border="0" alt=" photo 962B1A7D-663C-4BB8-84D9-340757D43836_zpswuiuogg5.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/FE3A018A-4F77-400E-B893-A2E178977951_zpsugkzbbuc.jpg" border="0" alt=" photo FE3A018A-4F77-400E-B893-A2E178977951_zpsugkzbbuc.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/0D2CE03B-C0B5-4B30-AD95-213F1EDE8A37_zpsvr4daxqx.jpg" border="0" alt=" photo 0D2CE03B-C0B5-4B30-AD95-213F1EDE8A37_zpsvr4daxqx.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/F0F7A497-7F41-4B82-A19D-83130AB955EE_zps7tn88py1.jpg" border="0" alt=" photo F0F7A497-7F41-4B82-A19D-83130AB955EE_zps7tn88py1.jpg"/></a>
<img src="http://img.photobucket.com/albums/v637/volvoist/1983%20242/DEA63403-6E1E-4C5E-A8A5-57C04A93D505_zpsn5u2m8aq.jpg" border="0" alt=" photo DEA63403-6E1E-4C5E-A8A5-57C04A93D505_zpsn5u2m8aq.jpg"/></a>
