1 - 16 of 16 Posts
“ A Swedish Meatball Fit For An Italian King ”
<a href="http://s42.beta.photobucket.com/user/brettborders/library/262c" target="_blank"><img src="http://i42.photobucket.com/albums/e323/brettborders/262c/IMG_2237.jpg" border="0" alt="Photobucket"/></a>
<a href="http://s42.beta.photobucket.com/user/brettborders/library/262c" target="_blank"><img src="http://i42.photobucket.com/albums/e323/brettborders/262c/IMG_2253.jpg" border="0" alt="Photobucket"/></a>
<a href="http://s42.beta.photobucket.com/user/brettborders/library/262c" target="_blank"><img src="http://i42.photobucket.com/albums/e323/brettborders/262c/IMG_2151.jpg" border="0" alt="Photobucket"/></a>
<a href="http://s42.beta.photobucket.com/user/brettborders/library/262c" target="_blank"><img src="http://i42.photobucket.com/albums/e323/brettborders/262c/IMG_2203.jpg" border="0" alt="Photobucket"/></a>
<a href="http://s42.beta.photobucket.com/user/brettborders/library/262c" target="_blank"><img src="http://i42.photobucket.com/albums/e323/brettborders/262c/IMG_2258.jpg" border="0" alt="Photobucket"/></a>
<a href="http://s42.beta.photobucket.com/user/brettborders/library/262c" target="_blank"><img src="http://i42.photobucket.com/albums/e323/brettborders/262c/IMG_2227.jpg" border="0" alt="Photobucket"/></a>
1979 262 C For Sale $10K Firm – This Car Is For A Serious Volvo Lover. I Need To Buy An XC90 2.5T With The $$.
VC2625MD005966
187K On Cluster But I Swapped It From Another 240. The Body Has 30K Less, So 157K, On It and The Engine Rebuilt Has 31K, Done The Summer Of 1999 With 157K On The Newer ODO.
I Have Owned This Car Since 1997, I Spend ALL My Money and Spare Time For 7 Years Of My Life On This Car, 1997-2003, I Recently Have Added A Son To My Life and My Priorities Have Changed, It Pains Me To Sell This Car, I Wanted To Be Buried In It When I Died.
Photo Bucket Pics-
HRE RIMS ARE NOT INCLUDED! You Will Need To Have Your Own Rims. Unless You Want To Buy Them…
Box Of Receipts For The Last 16 years included – Priceless
Original Window Sticker – Booklet
Total Strip Down Of Paint To Metal – Only 1 Layer Of Paint On Car – Except Front Spoiler/Bumper, Had Rock Chips, Was Repainted Last Spring – Painted Front and Rear Bumpers - $5500
Windshield NOT Cracked – I Have A NEW Volvo Windshield In Box For Replacement – $600
Basic Alpine CD Player/Stereo, Rear Speakers
Full Leather Interior, Sun Visors, Door Panels, A-Pillars, etc….
I’ve Owned The Car Since 1997, Bought Stock, Had 101K Miles
Garaged ALL The Time, Driven Maybe 500 Miles A Year For The Past 10 Years, Never Sits In The Sun, ALWAYS GARAGED!
Dash Crack Was Repaired At Dash Repair Specialist, Dash Fan and Ballast Was Replaced, Heater Core Too
MODS-
B21FT Rebuilt Motor – 2.3 Volvo Brand Turbo Pistons/Rings, All Bearings, Seals, Balance Crank/Pistons/Rods - Extensive Head Rebuilt, Paid $1000 Alone, B230 Intake Manifold (Polished, Valve Cover Too)…
Stage II Turbo Upgrade, Full Metal Compressor Bypass Valve
FULL Custom Turbo Back Exhaust – Cost $6000 Alone.
Custom Corbeau Race Seats W 240 Mount Brackets – Leather Wrapped $1500
R-Sport Steering Wheel With Extra Leather Wrap Cover To Make Thicker – Leather Underneath Is Still Good and Uncracked
New Limited Slip In Rear Diff, Full Rear Diff Reseal and New Outer Bearings/Seals, Chrome Rear Cover
Driveshaft Rebuilt and Balanced
M46 Rebuild, Upgraded Pistons, Stepped Flywheel, Turbo Clutch
Euro/Canadian Headlamps/Bezels (Bought New From Canadian Volvo Dealer), Glass Was Clear Bra’ed Before Putting On Car, Glass Has NO CHIPS or CRACKS – Pia Bulbs, Piaa Foglamps
New Flat Nose Hood From Volvo Dealer – Painted Gloss W Clear, Inside and Out
Flatnose Grill (Bought New) With GT Foglamp Trim and Fogs Installed, Fogs Not Hooked Up Yet, Lower Piaa Brand Foglamps Mounted Behind Spoiler
Full Wraparound Body Kit, RGA Design – I Have A NEW Spare Front 3 Piece Spoiler In Bag Still
All Exterior Emblems Powder Coated – NOT PAINTED, Handles, Trunk Latch, Crowns, Wiper Arms, ‘Volvo’ and ‘Turbo’ Badges, Grill Diagonal
NEW Volvo Brand Tail Lights
NEW 242 Turbo TRIM, ALL 7 PIECES – SOFT and PLIABLE!
MSD Coil and Boost Retard Control Unit
HKS EVC-EZ Electronic Boost Controller
All New Suspension Bushings
Front and Rear Coil Overs – Creaks Over Bumps, From MVP When They Made Them, Koni Adjustable Shocks and Struts
Full IPD SUSPENSION – Pan Hard Rod, Torque Rods, Sway Bars
No A/C But Have A Seized Compressor If You Want, Converted To No A/C P/S Pump Bracket
Trunk Lid Spoiler W 3rd Brake Lights – LED
Tinted Windows
Power Windows, Power Side Mirrors - Removed For Simplicity, Has Manual Crank Windows and Mirrors
IPD Cluster Panels, White, + White Turbo Boost Gauge, A/F Gauge, Custom Lower Panel W OE Ambient Temp Gauge, Mechanical Oil Pressure Gauge and Volt Gauge
Shifter Shortened, Bertone Leather Shifter Knob
Bertone Door Sill Badges (Bought New At Dealer), Mounted Driver Side, Not Pass Side Yet
License Plate Filler (bought new at dealer) Has Same Material As Tail Lamps
New High Volume Pre-Pump, Main Pump, Relay and Fuel Accumulator – All Volvo Brands, Not Cheap Aftermarket
Larger Front Wheel Bearing Hubs – From ’82- 240’s+
Optima Deep Cycle Battery + Machined Aluminum Optima Battery Tray
Circuit Breaker Mounted Above Battery In Trunk
Extra Climate Control/Center Control Panel Box
New Outer Door Window Scrapers
Lots Of Extra/Spare Parts-
Brand New Volvo Rear Bumper Cover In Bag Still
Round Headlamp Convertion Kit, Grill – Used
90+ B230FT Exhaust Manifold, Has Small Cracks
Extra Set Both Front Doors, Complete W Glass, Like New Door Panels
Rear Side Glass and Gaskets
Manual Rack and Pinion – Used, I Have NEW BOOTS and INNER and OUTER TIE Rods In Boxes Still, I Just Haven’t Had Time To Do It.
Short Front Driveshaft For M45 Conversion
Extra 86–up Black Trunk Lid If You Want To Eliminate The Trunk Spoiler
Extra NEW Oxygen Sensor
A/F CI Adjustment Tool
OE Windshield – In Box Still
Extra Driver Door Manual Crank Regulator
Manual Non-262C Side Mirrors From A 242
Extra Flatnose Grill With Broken Mount Tabs Included If You Don’t Like The GT Fogs
Stock CI Injectors and Lines
Volvo Factory Wiring Diagram/Service Manuals
Chilton’s Repair Manual
Haynes Repair Manual
JTR V-8 Conversion Book
Lots Of Other Clips and Misc Parts……
Please, Serious Inquiries Only… [email protected]
Colorado Car
I love you Brett but your pics are terrible. Here's a couple I have.
Obviously I've seen this car in person and it has the most flawless bodywork I've ever seen on a car outside of dedicated show cars. $10k is a steal for this car. Sorry to see you letting it go, but I understand completely.
Thanks Chris, Sorry For The Disappointing Photos.......
Oh, Yea, Also Has A IPD Turbo Cam, Adjustable Gear and Electric Engine Cooling Fan....
Holy crap I wish I had $10K. I spotted a pic of your car on the internet back when I was in college, and I have always wanted to find a 262 to turn into your exact car!!! Sadly I do not earn enough, so don't have the $$$, and it literally breaks my heart. Good luck with this sale.
free bump
Would you considor my girlfriend as a trade? :eek:
Or if your ever in need of a kidney...
lol. Good luck with the Sale. Such a beautiful car. Wish I could afford it!
Perhaps....I Showed You Pics.... ;)
Ends Sunday, Dec 9th
Discussion Starter · #13 ·
Somebody Hit 'Buy Now'. SOLD
Thanks All For You Guys Help!
Congratulations. :D I'll bet you were sorry to see her go though. :(
Discussion Starter · #15 ·
I Am Very Sad, It'll Be The 1st Time Since 1988 That I Didn't Own A 240..................................
That's gotta be fixed; check the "orphans" thread on TBs for sale forum. They find quite a few 240s on various Graig's Lists. :)
1 - 16 of 16 Posts
