1 - 6 of 6 Posts
What would you need an adapter for?
EDIT: You probably meant hubcentric rings.
Those are awesome and will definitely fit. Im running 19x9 +20 with (too much) room to spare. The v50 is running a 17x7/17x9 +10 with room to spare.
The center bore of that rim is larger than stock, I assumed some sort of adapter would be required. ( hub centric ring? ). I could run 255/45 18's, have 4.3% speedo error, I'd lose about 5/8 inch of wheel gap. And gain 5/8 inch of ride height.
Could I get pics of your 19 x 9 setup, along with all the specs of your wheel , tire combination? What is the off set of the wheel, and tire size?
I run 245/45/18 and they appear to have plenty of room.
1 - 6 of 6 Posts
