1 - 12 of 12 Posts
Does anyone have first hand experience mounting 18" wheels to thier V50 AWD without fender modifications? If so, what brand wheel and tire brand size combo did you use?<p>Thanks!
Re: 18" Tires Fitted to V50 AWD (mlenox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>mlenox</b> »</i></TD></TR><TR><TD CLASS="quote">Does anyone have first hand experience mounting 18" wheels to thier V50 AWD without fender modifications? If so, what brand wheel and tire brand size combo did you use?<p>Thanks!</TD></TR></TABLE><p>Try the search function - there have been numerous discussions about this. 18s are definitely feasible without fender mods - Volvo sells two options (Medea and Medusa) that need only new bump stops and steering limiters (and even those mods are questioned by some).<p>UKMatt
Re: 18" Tires Fitted to V50 AWD (ukmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>ukmatt</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Try the search function - there have been numerous discussions about this. 18s are definitely feasible without fender mods - Volvo sells two options (Medea and Medusa) that need only new bump stops and steering limiters (and even those mods are questioned by some).<p>UKMatt</TD></TR></TABLE><br>ya, I have 18" Medeas with 225/40 tires and volvo's stock 52.5mm offset, and no limiters/stops are needed whatsoever. Stick with narrower wheels and tires(ie 225 width) and there won't be any problems.
Re: 18" Tires Fitted to V50 AWD (s40turbo585)
I have 18" Medeas on my V50 AWD and its lowered too. No problems at all. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
I got my 18" medusas installed over the weekend with 225/40 R18 tires without any need for any mods or anything. I was upgrading from 17x7" Sagittas.
The Volvo site indicates that a software upgrade is required when upgrading wheel sizes. Is this correct?
Re: (quick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>quick</b> »</i></TD></TR><TR><TD CLASS="quote">The Volvo site indicates that a software upgrade is required when upgrading wheel sizes. Is this correct? </TD></TR></TABLE><p>They do recommend a speedo correction be applied but I question the real need to be honest - a stock 17" Sculptor to an 18" Medea, both with recommended tire size is only just over 2% different. That is, if your speedo says you're doing 58.7mph you're really doing 60mph. IMHO that isn't enough of a difference to worry about.<p>UKMatt
Re: (ukmatt)
thanks, Matt. This makes 100% sense.<br>-Chris
Re: (ukmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>ukmatt</b> »</i></TD></TR><TR><TD CLASS="quote"><p>They do recommend a speedo correction be applied but I question the real need to be honest - a stock 17" Sculptor to an 18" Medea, both with recommended tire size is only just over 2% different. That is, if your speedo says you're doing 58.7mph you're really doing 60mph. IMHO that isn't enough of a difference to worry about.<p>UKMatt</TD></TR></TABLE><br>The speedo correction is only if you use the Volvo recommended 215/45 tires which are about .4 in taller than the stock 205/50-17's. 225/40-18 is the same diameter as 205/50-17.
Re: (s40turbo585)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>s40turbo585</b> »</i></TD></TR><TR><TD CLASS="quote">The speedo correction is only if you use the Volvo recommended 215/45 tires which are about .4 in taller than the stock 205/50-17's. 225/40-18 is the same diameter as 205/50-17.</TD></TR></TABLE><p>exact same thing the guys at the shop told me when I got my wheels installed.
One thing to note is wheel rubbing generally has more to do with offsets and width then diameter. Really, if you use the proper tire sizes the overall diameter (wheel + tire) should be the same (or very close as some have mentioned). So basically, if you go from a 17 to and 18 but keep the offset and width the same (for example), as far as your car is concerned there is no difference.<p>If you push the offest out (lower number) or increase the width substantially, then you may have issues.
1 - 12 of 12 Posts
