I currently have 225-45-17 on a c-70 with the 32mm caliper. Can I go to a 50 or even 55 and have enough clearance?
Thanks
Thanks
Depends.
http://www.tirerack.com/index.jsp
Enter your '04 C70 then click on shop for tires.
Click on the 225-45-17 prompt.
Click again on shop for tires.
Use the dropdowns to enter your desired new tire size.
On any tire result click add to cart.
The system will ask you what car the tire is for.
Click on your C70 and the system will warn you if that tire will not fit.
Do that enough times and a chat box will pop up allowing you to "talk" with a real person at the tirerack.
George Dill
Probably not
