1 - 9 of 9 Posts
Is anyone running 245/40/19's on the stock wheels?
I'm assuming no issues vs. the 235/40/19's other than a slight speedo difference, but just seem like much more options with the 245 series tires.
Yep, lots of people.
I'm running them, no issues.
There is a software to get the speedo right when changing the tire dimension/wheel size. 245/40-19 is about two sizes too big though, even 235/40 is and I don't know why Volvo specifies that, or if they just were lazy.
Yes, Volvo as an application for various wheel sizes.
VDASH can also do it under ''Wheel and Suspension - Rolling Circumference''.
I have not checked the price however.
Yes, I run that size with zero issues. I didn't bother with the speedo change. It's minimal.
Do you have details on such software? I have not been able to get my car updated to read correctly with my 245/40/19 tires/wheels.
Last I heard VDASH did not work either as the TCM(may not be remembering correctly) threw an error if you attempt to make the change.
In any case it is about a 5% difference vs the stock 235/40/18s and easy to keep in mind while driving
Running with them too and change is slight (63.5mph in real on 65mph on my dashboard)
Application for 235/40 R19 Wheels coming from another diameter : 31414660
There is none specific to 245/40R19.
Brought my car in to try that at the dealer after finding that in VIDA but was told it showed as not compatible. I'll have to check the next time I am in
1 - 9 of 9 Posts
