1 - 11 of 11 Posts
Afternoon all,
I'm starting to budget $$ for my 140,000 timing belt service and wanted to get opinions on what else I should have done while they're that far in. I just saw JRL's recommendation of a water pump every-other timing belt change, what else should I consider getting done?
Thanks in advance. http://********************/smile/emthup.gif
(Oh, btw, '98 S70 GLT...)
Modified by kageryu at 2:23 PM 6-19-2006
Re: 136k, coming up on the timing belt, what else should I get done? (kageryu)
Quote, originally posted by kageryu »
Afternoon all,
i]Modified by kageryu at 2:23 PM 6-19-2006[/I]
At least take a good look at it. So at least consider, but not alway necessary
Volvo water pumps are (incredibly
) one of the GOO, long lasting parts on a Volvo and rarely fail but, if you're planning on keeping the car for a while, it's not a bad idea while the belt is off, no real extra labor (15-20 minutes).
Re: 136k, coming up on the timing belt, what else should I get done? (JRL)
Duly noted.
I've also heard some mention of timing belt tensioners failing, but I'm hoping any shop worth their tools would automatically do the tensioner w/ the belt! (I'm still going to ask when I set up the service, though!)
Anything else that is a lot easier to get to while they're doing this that I should specifically request they inspect?
Thanks again...
No, they don't always and that is what you need even more than the belt itself
Check for oil leaks around the cam seal but you would see this even before you opened it up
When I did the second timing belt, I asked to replace the water pump. The mechanic who worked on the car (20+ years Volvo tech, now has his own place) stated he replaced only several pumps all these years and said I don't need it.
I did serpentine belt as well.
Re: 136k, coming up on the timing belt, what else should I get done? (Papa_Kirlo)
Quote, originally posted by Papa_Kirlo »
Oxymoron, which is it?
Working on Volvos for many years he saw only few cars where pump replacement was necessary.
You should replace the little motor mount that is right there while doing the timing belt. It's a really weak piece and is almost always a sure be that you're going to need one. It's a few bucks more but worth it since the mechanic is already in that area.
Serp belt is also a great idea too.
Good luck and cheers,
Prospero
Re: 136k, coming up on the timing belt, what else should I get done? (Prospero)
Is that one of the two main lower motor mounts? I already got to pay to have those done last year.
Nope, there are two really large ones and then just this little one at the front of the motor. (front being from the pulley view)
Ok, cool. Thanks for the tip!
1 - 11 of 11 Posts
