I recently noticed my AWD not working a couple snow falls ago and brought it in to the local Volvo expert and he said my diff pump was not working and gave me an estimate but I have been working on cars since I was 17 so I figured I would give it a go. It was a pretty simple repair and dropped the vehicle down and took it for a test drive to have the AWD still not working. I have no codes at all so my question is do I need to reset something to get the new pump to work? If the diff fluid is a little low will that cause the AWD to not work or can there be something that can also cause it not to work without any codes whatsoever.
3.2l
Thanks
DH
Add engine info please for your 2007 XC90 AWD, could make a difference in this case.
Might be good to omit mechanical from the mix as a first step- https://forums.swedespeed.com/showt...king-or-Not-Angle-Bevel-Gear-Mechanical-Check , it'll look just like the problem you're having, with no codes being thrown. Couple variations on the theme, check with the car on a lift if you're not sure about the "test" with all four wheels on the ground.
If mechanical is sound, walk through the Xemodex troubleshooting flow for DEM- https://xemodex.com/us/diagnostic-flow-charts/ , see how far you get.
Good luck with your repair.
Thank you for that info, my mechanicals are fine but it failed the REM test, I tested the old motor which the repair shop told me was bad and it was working fine on 12 volts, I then checked the REM at fuse #23 and nothing, it looks like I get to have my REM repaired.
