So I picked up an 07 T5 AWD S40 with a broken timing belt. I had the head rebuilt and I just recently finished putting it all back together. Car runs fantastic. Where I could use a little advice is that the car makes a humming noise from the front end - the best way to explain the sound is like it has snow tires mounted on it. Having no experience with how the car sounded before I bought it, I'm not sure if this is how the AWD cars sound as a rule or if it's something else.
- Would a bad wheel bearing make this noise? How about an axle going south (although the axles looked good when I was in there replacing stuff). The tires literally have zero miles on them (the timing belt snapped at the tire shop - according to the previous owner. Could it just be noisy tires (they are Goodyear Eagle GT All seasons). Anything else?
It's not an engine noise as the humming is constant - doesn't increase with rpm's, it changes based on speed of the car.
I built the car for my daughter's first car and I want to be sure to replace anything that needs replacing - the last thing I want is for her to be broken down somewhere. Any help guys I would appreciate it.
Thanks,
Steve.
I was thinking old wheel bearing as well, trans bearing, rusty brakes, axle/cv joints.
I've had a low humming noise just like that for a few years now. It's not terribly a problem if it's the wheel bearing. My axles have been changed recently so I know it's not that. I'm guessing on mine it's a wheel bearing somewhere. Which one? I have no idea... but it's pretty common. The problem sometime with Volvo shops is that they want to replace the whole hub. It's frustrating...
Wheel bearing is easily detected by driving through a "sweeper" type turn or maneuver. If the noise gets louder one direction & softer the other you have a wheel bearing out. The bad bearing is the one that makes more noise when loaded. Ie. - Noise gets louder when turning left & goes away when turning right you have a bad right side bearing. You should be able to distinguish between front & rear without too much trouble.
pczeilon - thanks! I did exactly what you suggested and sure enough the noise did get louder when turning left and quieter when turning right. Looks like a new hub assembly needs to be ordered. Thanks!
