1 - 2 of 2 Posts
Hello, have a 06 Volvo XC90 2.5 I-5 and have a couple a questions on this and any help would be appreciated,
Have a pass side door lock when its locked the motor/cable seems like its keeps running ? is this common ? or something I have to rip apart the pass door panel to fix ?
Since this is a timing belt motor what is the service intervals for the timing belt to be replaced - "current miles 159k" cant find when car fax info on it if it was done last ?
Key FOB remote not working ? what should be done ? battery ? new key remote/fob ?
- really appreciate any input on this :) :bow:
2001 Volvo S80 Executive--135,000 miles
Check and see if anything is jammed in the door lock...
As for the timing belt, there should be a sticker (to the right of the washer fluid container of my memory is correct) that has the miles it was replaced at. Forum members, correct me if I’m wrong...
Start with a new key fob battery ;)
1 - 2 of 2 Posts
