06 s40 t5 awd m66
Ok, so within the past 2 months or so ive been having some problems with my 2006 volvo s40 t5, its AWD and has the m66 6 speed manual transmission, its all stock too. I cant seem to be able to pinpoint exactly what is wrong. A couple months ago it started hesitating then it got worse. After a bad shop experience and needless parts and money the problem persists. I decided to look at the plugs becuse it threw a couple misfire codes for cylinders 2,3, and 4 and listed plugs as the probable cause. The plugs were burned and corroded so i replaced them. Packs looked fine. After replacing the plugs the problem went away. But now, its back. It happens right after i shift and get on it. It hesitates and shutters. It hasnt thrown a code yet. The one time i want to see the light, it doesnt come on! I can also hear the turbo spool up and sometimes it doesnt sound right. Like it spools but then it misfires, stops prematurely. So anyway, i was thinking it might be coil packs, bad cat, tcv, turbo, vacuum leak, clutch, im just not sure anymore. It also seems to be better the closer to an empty tank i get (usually around a half tank it performs better). I would really appreciate any and all help or ideas and thoughts. I am also in the US.
