1 - 13 of 13 Posts
My XC90 got rear ended and we're going to be getting a new bumper. I'm hoping I could take this opporunity to install a generic reverse backup system. Body shop can order the bumper with or without the factory holes. I've found generic systems where most require a 20mm hole, a few require 21mm. I've even seen mention of 22mm sensors.<p>Can anybody tell me what diameter the factory holes are? And is it a nice clean flat hole that one could just snap a sensor into?<p>thanks!
Re: 06 reverse radar sensor size? (pattyweb)
I am not sure of the factory system size, but do not get an aftermarket system. The factory unit is ~$340 for the kit and not counting the bumper removal, takes ~20 minutes to install. You do need a dealer software patch, but it does work well. Also, it mutes the radio and beeps through the rear speaker. <p>I would not like to "rig" a system on a $50K+ vehicle when the factory one is affordable and reliable.<p><A HREF="http://vparts.autowebaccessories.com/store/volvo-xc90-reversing-radar-prod126_997.php" TARGET="_blank">http://vparts.autowebaccessori...7.php</A> <p>Also Brentwood Volvo in St Louis will usually beat anyone's prices on mail order parts.<p><A HREF="http://www.brentwoodvolvoparts.com/bvparts/index.jsp" TARGET="_blank">http://www.brentwoodvolvoparts...x.jsp</A>
Re: 06 reverse radar sensor size? (Colorado XC90 T6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Colorado XC90 T6</b> »</i></TD></TR><TR><TD CLASS="quote">I would not like to "rig" a system on a $50K+ vehicle when the factory one is affordable and reliable.</TD></TR></TABLE><p>I would not consider the factory system affordable. It's $340 and most likely my dealer would charge me at least another $100 for the software install. At least $100 to install software to make a feature work that's technically already plugged in. What a joke. Thank god we don't need software updates whenever a bulb blows. <p>I can get an aftermarket system for under $100. I wouldn't be surpirsed if it used the same electronics as volvo seeing as volvo doesn't really make this system, some company in europe supplies most everything for everybody (I found volvo listed at their site a while back). Reliability isn't an issue either. <p>Anyways, that's not the real issue why I'm not wanting to go with the volvo system. I now have an aftermarket stereo installed and the factory amp is not doing anything so it would be harder for me to make the factory system work properly. My new stereo has a mute wire that I can make use of. 12v and reverse light are all set and ready to go in the back where the new amps are. An aftermarket system would be easiest right now.<p>The gotcha is that the body shop can order one of two bumpers for the car. One comes with the holes premade. I can't find out what size holes they are though. I'd hate to get the bumper and find that the holes are bigger than necessary because volvo uses some wierd spacer, insert, snapin, whatever and then be forced into the volvo system. <p>If I can find out what size the hole is and it works, then I'll get it. Otherwise, I'll just get the same bumper and worry about reverse sensors some other time. Was just trying to get them in since the body shop was going to have to replace the bumper.<p>pat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>pattyweb</b> »</i></TD></TR><TR><TD CLASS="quote">...I'd hate to get the bumper and find that the holes are bigger than necessary because volvo uses some wierd spacer, insert, snapin, whatever...</TD></TR></TABLE><p>Yes, Volvo's sensors use bushings:<p><IMG SRC="http://pictures.dealer.com/bostonvolvo/8cf963f34046385c00f75a7105a743f8.gif" BORDER="0"><p>The sensor bushing part numbers are different in fact for the left, right and center bushings.<p>John Sharisky<p>
Re: 06 reverse radar sensor size? (Parts @ Boston Volvo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Parts @ Boston Volvo</b> »</i></TD></TR><TR><TD CLASS="quote">Yes, Volvo's sensors use bushings:<p>The sensor bushing part numbers are different in fact for the left, right and center bushings.</TD></TR></TABLE><p>BTW, the bushings are different so the sensors can point in the right direction, since the bumper is not flat. The bushings help accomodate the curves in the bumper.<p>May be your dealer may be able to get you just the bushings? Or you could try a local junkyard.
Thanks for the reply! Looks like I'll just need to go with the regular bumper and do this some other time.<p>Out of curiousity:<p>Does volvo sell those bushings separately? If so, how much and what diameter are the volvo sensors themselves?<p>What's the part number and cost for the volvo punch tool?<p>pat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>pattyweb</b> »</i></TD></TR><TR><TD CLASS="quote">Does volvo sell those bushings separately? If so, how much and what diameter are the volvo sensors themselves?</TD></TR></TABLE><p>Yes. Your price from us on the bushings is $2.63/each. I have no way of knowing the diameter of the sensors.<p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote »</i></TD></TR><TR><TD CLASS="quote">What's the part number and cost for the volvo punch tool?</TD></TR></TABLE><p>I can sell you a rear park assist punch-tool at $12.44.<p>John<p>
Go aftermarket.<p>The Volvo system isn't very good. It allows you to get too close to an object before it starts warning you... my $.02 worth.
Pattyweb, for $24 you can get the four bushings and the puch tool and do the install at any time.<p>for $2.63 you can get one bushing and see the inside diameter find out if the aftermarket sensor works or not, then go for the rest later.<p>
Re: (Emission)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Emission</b> »</i></TD></TR><TR><TD CLASS="quote">Go aftermarket.<p>The Volvo system isn't very good. It allows you to get too close to an object before it starts warning you... my $.02 worth.</TD></TR></TABLE><p>Really? Mine starts beeping when I'm 4-6 feet away from anything. Most aftermarket systems I've seen have roughly the same range.<br>
Re: (Emission)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Emission</b> »</i></TD></TR><TR><TD CLASS="quote">Go aftermarket.<p>The Volvo system isn't very good. It allows you to get too close to an object before it starts warning you... my $.02 worth.</TD></TR></TABLE><p>Range is 4.9 feet.
Re: (VolvoMax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>VolvoMax</b> »</i></TD></TR><TR><TD CLASS="quote">Range is 4.9 feet.</TD></TR></TABLE><p>Which is adequate for parking.<p>However, there's lots of yokels who use it as some sort of rear navigation sonar, backing out of parking spaces or driveways relying on it to "see" everything in it's path for them. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0">
Re: (1sttimevolvo)
No amount of electronics can replace good judgement...
1 - 13 of 13 Posts
