Removed from my wife's totaled car with 165k highway miles. Car was driven by two ladies, never modified or abused. Transmission has no issues. Shifts smooth with no abnormal noises or clunks. Fluid was replaced every 40k miles as preventative maintenance. $300 obo
Might want to provide transmission serial # so that interested parties will know whether this is a faulty valve body trans or not.
TNN43-53-2007-11-09 Title: Auto Trans - TF80-SC Diagnostic Information Summary - Valve Body Replacement.
This document summarizes customer complaints related to the 6 speed Automatic Transmission (TF80-SC) and should be used together with the information in VIDA.
The Valve Body should be replaced to address the following symptoms:
1. Customer complaints about 2-3 upshift quality. The shift may be described as harsh, or as a shudder. The symptom is usually more apparent during the first few minutes of driving after a cold start.
2. Customer complaints of shudder when slowing down, just before coming to a stop. The symptom may also be described as a harsh downshift just before coming to a stop.
3. Neutral condition in 4th, 5th & 6th gear; normal behavior in 1st, 2nd, 3rd & Reverse. One or more of the following DTCs (Diagnostic Trouble Codes) may be present: P073400, P073500, P072900, and P089600.
4. Neutral condition in all gears except 5th & Reverse, usually with DTC P273300 set. DTCs for gear ratio(s) may also be set such as P073000, P073100, P073200, or P073400.
Note: Transmissions starting with serial number 06J and later already have the latest valve body which is designed to prevent these symptoms.
Thank you for the information.
Here are the photos of part number and serial number. Serial number starts with 05J.
bump
October bump
