Update:
The "S" button feature failed. I disassembled shifter assembly to attempt to clean circuit. Reassembled and test. Only works when in Advanced Mode.
I do have a used shifter assembly to install. Are these plug & play?
Thank you
Probably.
It depends on what you consider to be a "Shifter Assembly"
Probably.
I consider it to be the shifter assembly, probably.
If you are not going to assist in helping me or others, don't respond.
Does the light on the S button come on when used ? start trying to isolate whether it's a simple button fault.
I've not done anything to do with the trans on Vida so I'm unsure if it recognises what mode the trans is in, if it does then that would be immensely helpful
