The car will start but then bogs out and dies. It will do this for about 10-20 times. Once it stays running there is no power loss and no engine light and will run the rest of the day but if it sits overnight or while at work it wont stay running. Any ideas on what to look at first? Has it happened to anyone else? Thanks
Have you had the PEM recall fixed? That's the fuel pump electronic module or some similar acronym... Caused my car to die a few months ago. If it's not your problem, you should get it fixed before it breaks you down anyway.
Re: (mattdoc)
Sounds like SSS - Start Shudder Stall. Never happened to my ride but there's a a ton of information of you search the forum from those unlucky to have gotten it. Why you're experiencing it now so late is a mystery and might be unrelated.
