1 - 13 of 13 Posts
This started after driving my v70r to Tahoe. It sat for a few days in <32 degree temps. When I started driving it back home, it did this.
In the vida/dice there are no codes stored. I thought it was a bad coil, but I believe that would have a misfire code?
Here's a video of it:
https://www.youtube.com/watch?v=WI1Om9dnKhQ
Any ideas? I thought it could be the TCV but it has an upgraded ipd tcv.
My idle was stumbling at idle just like yours but for me it was a fuel issue where I did have codes stored pointing to the fuel pressure sensor, but it was a bad fuel pump. I also had complete loss of power where the car would cut off at WOT between 3-4k rpm, but not where it felt like I only had half of the power before that fuel cutoff, it just cut off without warning, so I doubt you're having the same problem as I was having. Seems like a vac leak could be a good place to check. You might also simply be losing boost and without a boost gauge idk how you'd go about finding that out.
fuel pump was replaced by the previous owner...
Just ordered a vac/boost gauge, hopefully that reveals something. I just got this car a few months ago, been nothin but problems - one after another. Kinda frustrating.
Could you try using either vida or a generic scanner to look at the fuel pressure kpa while you're driving? If it stays at a constant ~400 kpa even when accelerating you might have ruled out fuel system issues. No codes leads me to believe its either a leak somewhere/you're losing boost. A loose gasket, bad hose, bad cbv, bad turbo entirely, who knows.
I have also seen other people while forum browsing from the problem I was having with people having problems with the ipd tcv and they go back to the oem one or pierburg, it could be that simple.
Ok, got the boost gauge.
At idle in park it's solid at -20.
In D it drops to -19 and does that stumble in the video.
Flooring it it gets to 6-7psi, sometimes 8, and just stays there and makes that shuddering noise. So since I guess that's just wastegate pressure, bad TCV or CBV?
welp, fuel pressure is steady at 400kpa...
I've replaced the ignition coils, the plugs, and the TCV, still tops out at 7psi and stutters there.
Next I guess I'll clean the MAF, do further leak testing, then take the heat shield off and see if the CBV holds vac... wish there was a ****in code
Is your tcv getting the correct signal? It's kind of acting like the tcv isn't plugged in, so I would take a look at wiring.
IPDs TCV is a piece of junk... Swap that first.
yep, replaced the ipd tcv with a pierburg tcv, no difference.
Should I hook the boost gauge up to each of the lines running into the tcv and see what they read?
1 - 13 of 13 Posts
