1 - 1 of 1 Posts
So I know this isnt a question specifically for an R but I don't seem to get much of a response on the other forums so Im posting it here to see if I get a better response..
My mom has a 2004 V70 non-turbo 2.4 Liter that started popping a consistent check engine light. When I pulled the codes on my generic OBD2 reader I got the following codes:
OBD2 - confirmed:
P2227 - Barometric Pressure Sensor "A" Circuit Range/Performance
OBD2 - confirmed:
P0106 - Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance
I reset the codes but they came back on pretty quickly. The car seems to run fine although it seems that the engine is working a little harder than it should at times, and at one point when I let it idle after a short drive the idle seemed to fluctuate up and down for a bit and then went back to normal. Anyone else had these two codes come on together and what was the diagnosis/solution??
Any help would be greatly appreciated.
Thanks,
1 - 1 of 1 Posts
