1 - 19 of 19 Posts
I have been lurking for awhile now, and recently decided to make my account here. This is my car, and what I hope to do and have done with it.
bought at 130K June 2013 , 1 owner before me.
'04 S60 2.5T AWD
-stock Xenon head lights
:: :WINTER 2015:
Currently at 160K miles February 2015
[done]Stage(0)
Have done :
-[done]-replaced timing belt + water pump at 140K
[done]-replaced all filters [155K]
[done]-oil changed every 6-8K miles [most recent at 160,899]
[done]-new all weather tires at ~155K
[done]-a drain and fill of the power steering fluid [160,930] filled with CHF11s ~1.3 +Liters
[done]-replaced fuel injectors, coils, and spark plugs [168k miles]
What I need to do:
-recently have had the parking brake break, going to have to replace this {see this thread}
-repair the weather strip on top of the windshield [looking for this part]
Stage (2)
[done]-repaired fog lights, and the inner bumper part that the fogs mount to. see here : part #3 on this link
[done]-HID conversion for the Fogs (got some 55W HIDs at a good price)
turbo down pipe + catback exaust , snabb intake, fmic
-[front done]replace/ upgrade the suspension to performance suspension
-replace PCV hoses
-touch up all paint/paneling on the car
Stage(3)
-switch out turbo for K24 or 19t turbo
-new brakes, R rotors,R calipers (red)
-full spec upgrade to work with turbo [billet compressor wheel and matching compressor housing 19T or K24 at same cost] see here
-aesthetics :
--paint rims black [plastidip]and rotors black
On the edge about:
-a drain and fill of the transmission fluid [attempting to figure out what I need to fill with] [no current issues, may let it sit until a later date]
==computer upgrades I'm looking into==
-Euro fog
-shifting upgrade
-fluid reset for the transmission fluid
recently got a new tool kit ! then put it to good use 160K power steering flush and switch to CHF 11s
Basically, if anyone has any advice I'm 100% up for hearing it. This is my first car, and I am looking to learn.
Looking forward to you build this car up! I don't have much to input as it looks good, but make sure you get a tune and bigger injectors if you put a K24 or 19T turbo in there. I have a 05' AWD 2.5T swapped with a 19T turbo. I've posted that I got tired of it rather quickly, but that's sort of changed. I have since fixed my throttle body tube and rear O2 sensor and now the car is great to drive. Pulls great, boosts great, and is just all around fun. However I do think it's a heavy car to really try and make good hp/ton. I read so many curb weights, but the average I see is 4000 lbs. With my 19T and 315~ hp that's only 158 hp at crank/per ton and maybe 120 to the wheels/per ton. At least there's boatloads of torque (about 360 ft/lbs total in my swap)!
what got tiring with the turbo? do you have a link to what you did?
I don't mean to put you off, it's still much faster and more fun with the turbo swap/upgrades. My initial point was to say I ended up dumping a lot of money into this car. Enough that I could have sold it, bought an S60R and put a little into that. So with how much I spent, the weight of the car, and the fact that it's an automatic makes me wish I had thought a little more about putting money into this car. Now that everything works well I don't regret it, it definitely gets up and goes... but it just was a good chunk of change.
I think this was my thread with the "build" but it's mostly questions and not anything like a write up. http://forums.swedespeed.com/showth...money-is-ready!-How-would-you-build-your-2-5T I'll try helping with questions, but there are plenty more knowledgeable people on here than me (plenty lol).
I have been thinking that is the main thing..with the car, but i think my resale at 160K miles is prob only 5k? ...tops which I dont think is enough to get an R ... how much did the total switch cost, about $1000 or was it the 2k number in the thread?
I seriously have been considering getting a shiftmatic/geartronic volvo...but once again it boils down to money
Oh, yeah I got my car with really low miles on it (under 40k) and still am only in the 60k range now. Plus I paid a little too much for it lol. It was more than $1,000 for sure. Turbo w/11 blade turbine was $1,065, tune was $580, refurb injectors $130 for the set, new silicone couple like $12, ECU removal tool $55 (unless returned for a full refund, but I just kept it) bringing it to $1842 for that. I also installed a front mount intercooler to make sure I could handle the power. Home made kit cost about $200-250 (replacing parts here and there, could be done for cheaper). Full exhaust through OBX to help with the bigger turbo was $575 (DP and catback, but you will spend $100-200 more to get a catalytic converter welded in if you need one). New fluids went into the car, new coil packs, OEM plugs, snabb intake pipe, new PCV system... so it's over $3,000 and that doesn't include the other things I put into the car.
You can definitely get used turbos to help with price there. Injectors you could do the same, I got mine with the turbo from ARD. FMIC I saved about $500 on from not going aftermarket... but my guess is you'll still spend over $1,000 easily.
I spent something like $6400 on the car before taxes and registration . I have put almost 850 into it including tires,oil changes, water pump+ timing belt, break removal...for the parking break... ($100 at the shop labor ..i was watching it was a mess to get it operable)
I was thinking a used turbo then get the computer upgraded.. I figured my exhaust system would hold.. on the version I had, but at that cost it may not be worth it. I figure ill have my car for another 4 years or 9 depending on grad school... ( and keep this one because i love it) + and buy another, but a very lightly used manual technical when i graduate university...
The point of the upgrades I listed are to help support the extra power that can be made on these larger turbos. Swapping to a 16T could be more budget friendly instead of the 19T or K24, but of course at less power.
yesterday I flushed my power steering and switched from ATF to CHF 11s , paid for an oil change...because it was 8F and I couldn't wait any longer.
I also broke my fog mount + the inner backing to the bumper where it connects to on a block of ice that fell off a car..so im going to be looking into that repair ASAP.
I also decided that i want to put performance suspension into the car, pain the tires black, buy and paint R rotors black and use red R calipers...
so my next to do list looks like :
fix parking break
fix fogs
upgrade suspension
upgrade brake system
Discussion Starter · #11 · (Edited)
Update***
repaired my rim for $110 and got the new tire for $40 thanks to insurance (tire is re insured as well, and i get free rotations)
=== currently doing the following ===
ordered and will be replacing my wheel bearings (front) see this thread : http://forums.swedespeed.com/showthread.php?226708-2004-s60-wheel-bearing-replacement-%28front%28s%29%29-need-parts-help
i bought new fog lights and will be replacing the housing(s) as best i can. my hids are having some problems with install so we will see how this goes see here : http://forums.swedespeed.com/showthread.php?226705-Fog-hid-replacement-questions
Discussion Starter · #15 ·
what i am purchasing for my front suspension replacement at 165k miles
this is my mix and matched fcpeuro kit. it is $50 cheaper then their listed equivalent
Item Qty. Total
Volvo Strut Kit Front 2 Piece (S60 V70 S80) - Sachs KIT-P2SRTKT2P2 1 $267.99
Volvo Strut Mount Spring Seat (850 S70 V70 P2) - Sachs 8646713 2 $41.98
Volvo Suspension Strut Mount (S60 S80 V70 XC90) - KYB 30714968 2 $131.98
Volvo Strut Tool (850 S60 S70 S80 V70 XC70 XC90) - CTA-A446 1 $17.99
Volvo Bump Stop Kit Front (S60 S80 V70 XC70) - OEM Rein 8672087 2 $23.98
Volvo Strut Mount Brace Left (S60 V70 XC70 S80 XC90) - Hutchinson 8666205 1 $19.99
Volvo Strut Brace Mount Right (S60 V70 XC70 S80 XC90) - Hutchinson 8666204 1 $19.99
Volvo Suspension Strut Mount Cap Front (850 S60 S70 S80 V70 XC70 XC90) - OEM 3064796 2 $17.98
Volvo Suspension Strut Mount Fitting Front (850 C70 S60 S70 S80 V70 XC70 XC90) - OEM Supplier 31262068 2 $21.98
Volvo Sway Bar Link Kit Front (S60 S80 V70 XC70 XC90) - Karlyn 274456 1 $23.99
Volvo Strut Mount Lock Nut Kit (1 Mount) - CRP 948645X3 2 $1.98
Order Total: $549.83
Discussion Starter · #16 ·
Item Qty. Total
will be ordering the parts today and rebuilding the suspension .
Discussion Starter · #19 · (Edited)
1 - 19 of 19 Posts
