1 - 2 of 2 Posts
Had a set of projector HIDs from an 04 sitting around. Finally sourced the appropriate wiring harness. Known good ballast and bulb.
Xenon bulb will ignite but shut off after a few seconds. Tried it on both passenger and drivers side. My 06 came stock with halogen.
Other than trying a different bulb and ballast is there anything else I should check? The halogen lights work fine.
A member in the r forums mentioned the halogen lights use a pulse width modulated signal for the hid lights. Wondering if anyone has dealt with a similar issue here?
Too much current draw on ignition. You could try a drop in D2x led.
1 - 2 of 2 Posts
