Hello everyone. Today my wife's xc90 stalled on me upon startup and only after shifting to drive. It started up normally and has been running fine. A month ago the car did have trouble starting and displayed the engine start prevented message a few times but has since not done again. I did some reading on both these issues but have not found anything to lead me in a clear direction.
I did read about the key sensor ring in the ignition that could be bad. Possibly corroded wiring on the starter. MAF sensor in another thread was possible cause. Another thread same symptoms said fuel pressure sensor. Another said clean throttle body and PCV.
Now earlier today before the stall the engine did stumble some but cleared up. Also after the stall tonight it started right back up again no issues.
So I know the PCV probably needs replacement soon. Car has 114k. Rubber glove over dipstick and oil cover sucks glove in .
Car uses 1 quart oil in 7500 miles. Spark plugs replaced Volvo brand recent. All coils replaced. That was a different symptom btw when the coils started going bad .
There is no check engine light coming on. Fuel filter replaced in last 10000 miles. Have not done a fuel pressure test.
There are no messages in the driver information center.
Is it reasonable to think this is related to the recent ignition problem with the start prevented message?
Im open to hearing ideas or others that have had this problem and found a fix. Thanks for reading!
Andy
Andy
